Results 1 to 23 of 23
    Nov 2013
    Lutz, fl
    Default Battery maintainer
    This is at Lowe's in the hardware department.
    It appears to be a rip-off brand. "Battery ex-Tender" as opposed to the most used brand "Battery Tender" or "Battery Tender Jr." If its made in China maybe better to spend the extra $6.00 and get the real thing.
    Apr 2014
    Beloit Kansas
    I don't know, maybe when there is 20 plus years of history and millions of satisfied customers to back it up.
    Until then , will probably stick with my Deltran Battery Tenders. Tractor, mower, UTV, Spyder... never a doubt
    how these will work.
    Default Well....
    Looks nice you could give it a try and then review it for the folks and build it a rep....did not see if they had any reviews....
    Jul 2015
    Dorr, michigan
    Ratings on Amazon pretty good, 65% of the people gave it 5 stars, 4 stars overall, thats with 26 reviews. Price there is little over $36.
    2020 RT Limited , Petrol Blue
    Aug 2012
    CO
    I bought this one from Lowes over the winter, <$20. It has a float mode as well. Works fine on our Spyder. Most battery maintainers are all made in China regardless of the brand anyway. My battery doesn't care where it gets its electrons. I also have Deltran Battery Tenders in the shop - they all work the same. The only one that crapped out on me was a Craftsman from Sears.
    JLohPhotos
    2008 GS , Millennium Yellow
    Mar 2011
    oregon
    I'll bet that battery tender is also made in China show me any electronics that aren't
    Sep 2016
    Lewiston , Maine USA
    Default Battery "Extender"
    I've had one of these for eight or nine years. Still working fine!
    Quote Originally Posted by r1100rider View Post
    I will take a look at my Battery Tender Jr's the next time. Just trying to point out that some may have bought the Battery ex-Tender thinking it was the real thing. Usually, knock offs are branded very close to what they are copying.
    A blast from the past: When I was in the leather business, we sold handbags. For a time, Latigo was the in thing. Beautiful oil tanned leather, black, brown, tan. The K-Mart stores sold knock offs. They called them LatisGlo. They were genuine vinyl and not very good at that. Not the leather that people thought they were getting for half the price.
    Caveat Emptor--
    Apr 2017
    North Central Florida
    Quote Originally Posted by Eagle1 View Post
    Yes.....so......what's your point?
    Reasonable at the reduced price but overpriced at the regular price listed......for a 1 amp unit.
    Schumaucher is an old time name in chargers.
    Quote Originally Posted by asp125 View Post
    Float mode is not maintainer mode. Float can kill your battery from overcharging since it is a constant, albeit very small, charge current. Maintainer mode cycles the charge current as needed to keep the battery at full charge.
    Dec 2008
    Syracuse, NY
    I have an Odyssey PC680 battery, and their Ultimizer to go with it. They have a 3 step charge profile, and I haven't had a problem in the 5 years I've had the battery, and notice the last phase:
    • Bulk Phase – Fast charges the battery up to 14.7V and gets the battery to about 80% state of charge
    • Absorption Phase – Finishes off the charge in no more than an additional 4 to 6 hours after completion of bulk charge
    • Float Charge – Continuous trickle charge will keep the battery topped off and ready to go
    Apr 2017
    Totally, absolutely, 100% wrong.
    A float voltage set at the proper point is no better or worse than a voltage that turns on and off.
    As a matter of fact, most battery maintainers use the float method and do not turn on and off.
    Now.....anything labeled as a "trickle charger" can indeed cause damage over long periods due to overcharging and gassing.
    And you are totally, absolutely, 100% correct. I don't why I was thinking 'float' was the same as 'trickle'. I'll blame it on age!
    The unit in the OP is a maintainer from Schumacher. A look at their website shows that Schumacher has quite a variety of chargers, charger/maintainers, and maintainers. I would have no reluctance to buy and use one. But considering the one that asp125 refers to, the one in the OP is not a bargain.
    Apr 2017
    It is nice to post a correction and not have it turn into a flame fest.
    Thank you.
    Note: I've been an Electronics Engineering Technician for about 50 years now so I've got most of this electricity stuff down.
    Mistakes do happen though; age is a good excuse.
    Yes it is. Perhaps this is an exception to the "usual."
    Nov 2013
    Lutz, fl
    It is a Schumacher brand, not a knock off.
    Nov 2013
    Lutz, fl
    I have this same unit as you, the one pictured is also a Schumacher brand at a reduced price. The price label says Schumacher brand.
    MG]https://mobileimages.lowes.com/product/converted/026666/026666709705_07926070.jpg[/IMG]
    I bought this one from Lowes over the winter, <$20. It has a float mode as well. Works fine on our Spyder. Most battery maintainers are all made in China regardless of the brand anyway. My battery doesn't care where it gets its electrons. I also have Deltran Battery Tenders in the shop - they all work the same. The only one that crapped out on me was a Craftsman from Sears.[/QUOTE]
    Dec 2008
    Syracuse, NY
    I've used Deltran in the past, and they are excellent, but they are not for all batteries. I have an Odyssey battery, and I called Deltran, and talked to one of their technical people about the specs on the Odyssey/Ultimizer, and they agreed that the Ultimizer was the way to go.
    Feb 2015
    New Orleans Westbank - Belle Chasse, La 70037
    Default Help this novice decide on the right type of battery charger
    I've been reading all this stuff about battery chargers and I'm more confused now than I was when I started. I have a 1.5 amp Schumacher SpeedCharge Battery Maintainer and Charger I got from Walmart for $25 +/-. I havn't used it yet cause I'm scared I'm gonna burn something up or waste my money. Can anyone tell me if this thing is good to use? Thanks
    Quote Originally Posted by jimmybarton View Post
    I would trust Schumacher. Read the user manual. If it warns against leaving it connected, take it back. If it specifically says it's a maintainer, use it.
    Apr 2017
    Yes it is fine. Perfect in fact.
    Regardless of the subject matter, every Internet forum that exists has a few participants who think they know more than the engineers and who are obsessive/compulsive about making sure everybody knows it.
