Page 1 of 2 12 LastLast
Results 1 to 25 of 30
Thread: OEM rear tire
    Jun 2016
    Phoenix
    Default OEM rear tire
    How many miles did you put on the new rear OEM tire before you replaced the tire?
    Active Member LLSailor's Avatar
    Jun 2012
    Leavenworth, KS
    Got 11,000 on the first and 9500 on the second.
    Pat
    Burp(Gone, but not forgotten) - Viper Red 2012 RT-S SE5
    B-2 - Intense Red Pearl 2016 RT-S SE6
    GP - Phoenix Orange 2019 F3 LTD
    Very Active Member Warlock's Avatar
    Oct 2011
    Magnolia, Ms
    Quote Originally Posted by marty1096 View Post
    8000 miles on mine and wore out.
    David
    Jun 2016
    Harrington, Australia
    500 miles and I'd had enough. The Kendas do make a nice garden planter for potatoes though !
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
    Five assorted Spyders. Have always replaced with OEM's. I average 13,000 to 15,000 on all but the 2014 OEM which was a softer rubber compound. I only got 8,900 on that one.
    You did not ask, but fronts are 20,000 + in all cases except for when the alignment was off on the 2011. Got 12,000 on those.
    Dec 2014
    S.E. Michigan
    Got about 15,000. Might have been pushing it.
    ~Sandee~
    ~Sandee~
    2016 RT-L (Purchased used in February 2018)
    RT Dash Mount (from JT's Spyder Store)
    Kuryakin Trident Highway Pegs
    Hopnel Pouch
    Magic Mirrors
    Spyderpops Foam Handgrips
    Iron Butt #35273
    Girls on Spyders #2779
    Default Well....
    Got 19,000 on the first 16,000 on the second...got more agressive. This is on an RS manual the RT's and the auto's get less. Got 33,000 on the fronts still on the second set.
    ​2012 RS sm5
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    AJ
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
    Dec 2013
    4800 fairly high speed & hot miles on my OEM rear tire, which I believe was one of the soft compound offerings but never provided much traction or good handling!! So when I replaced it, I went for a 'real' tire instead of the Kenda crap, & that 'real tire' I've just swapped out after 30,000 of waaaay better traction, ride, & handling with greater loads aboard & mainly hotter ambient & road surface temps too!!
    Didn't do too much better on the fronts tho, they were cactus by 5200 or thereabouts, but after replacing them then, now 30,000 later the A/mkt replacements still look less than half worn!!
    Active Member WellsboroSpyder's Avatar
    Feb 2014
    Wellsboro, PA
    We are up to 15,000 right now.
    Traded 2013 rt s se5 for pearl white 2015 RTS se6 .
    Gloryder hubs
    622 trailer
    bumpskid
    Wife and I have been a couple since 1980
    32 years of wedded bliss
    Sep 2014
    USA
    5800 miles tire was almost bald
    Mar 2015
    Brockport, NY
    Default Right around 9000
    Wore out in the middle, as most of the factory have seemed to.
    2014 RT-S Pearl White
    Sep 2012
    Stetson, Maine
    12,000 first Tire, 10,000 second, 7,0000 third (soft Tire compond). 14,000 on kumo, now.running General Altimax. Bruce
    Active Member Luvs2Ride's Avatar
    Apr 2013
    Mechanicsburg, PA
    Default Tire
    16,500 - replaced yesterday.
    May 2013
    Apex, N.C.
    I barely got 8k on my first one on the RT. At that point, I was on vacation in the NC/Tenn. Mountains and drifting around nearly every turn. I will add that I was riding a little agressively.
    Very Active Member KX5062's Avatar
    Aug 2012
    Central Coast, CA
    4,000 on mine, but I did get one of the soft batch. However, on my previous Spyder I didn't have one of those and still only got about 6,000 on that one.
    2020 RTL SE6
    Mar 2013
    Marion, Arkansas
    Right now I have 10500 miles and is pretty much toast in the middle of the tire. For sure going to a car tire in the near future. MY fronts still are looking good. Probably will get another 10,000 out of the OEM fronts and then be going to car tire up front also.
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
    Jul 2014
    Mint Hill, NC
    I have 9,400 on the new, harder compound tire with still a good bit of mileage left. I'll probably push this one as far as I safely can locally so I have as fresh a new tire as possible for the long trip to Red Rocks.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Vermont
    5,824 miles. Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Nov 2012
    North Las Vegas, NV
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Very Active Member Fat Baxter's Avatar
    Sep 2014
    Central Alabama
    I got only 6,900 on the rear; replaced with a General Altimax. I now have just under 20K total on the bike.
    Replaced the front Kendas at 12,000 with Kuhmo's. I got tired of the jiggling and bouncing. Bike is SUPER smooth now.
    Oct 2016
    Faribault, MN
    Just over 10,000 and really needed replacing.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Jan 2016
    hudson,pa
    Default .
    got 10,500 on mine
    Sep 2014
    USA
    Quote Originally Posted by DGoebel View Post
    Did you ever get the bearing noise issue resolved?
    I got 5,700 miles out of the Kenda...
    But I've got 11,300 miles on the Kumho that replaced it, and it still has a fair amount of tread left!
Tags for this Thread
