Results 1 to 15 of 15
    Mar 2016
    Newton, Iowa
    Default Looking at 2014 Rt out of warranty
    I'm looking at a low mile (less than 4000) 2014 Rt-S that is out of Warranty. I had the DESS issue on my F3 so my concern is the same issue with the 2014. What does it cost to upgrade the DESS system and is it something I can do myself? Thanks.
    I have 24,000 on my 2014 RT-S. Never had a DESS issue or a major glitch that needed warranty work.
    Vermont
    Quote Originally Posted by Godlover View Post
    Does the 2014 RT-S still have the B.E.S.T warranty in force?
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Deanna
    I know you are not addressing me, but I got 2 free years of BEST with my purchase and I am good to go until 4/2018.
    Mar 2016
    Newton, Iowa
    Deanna
    No, he bought it in February of 2015 and did not get an extended warranty. So, I would not have a warranty.
    Jun 2010
    Las Vegas
    If you are looking to purchase a 2014 RTS that is still under warranty until February 2019 give me a shout.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Sep 2016
    Parma, Idaho
    Default BEST Waeeanty
    I purchaed my 2012 Can Am Spyder RT-SE5 preowned in 2016. It now has just over 23,000 miles. I've just paid for a new multifunction display, as the one in there, died on me. Can I purchase a BEST warranty at this point?
    Default DESS ISSUE - POSSIBLE FIX
    The module part costs about $ 135.00 ( PROCALIBER.COM - register for FREE and get discounted prices ) ... I moved my Module last year so it could be re-placed in 5 minutes if necessary ...... and you can do this in advance also if you want ......... the frunk must be re-moved to get to the module ........ it's attached to the " firewall " just above and to the left as you face the frunk area ..... it un-bolts , as does the harness wiring and plugs ..... I moved the Module ( there is more than enough wiring to do this ) to just under the right front headlight and bolted it ( using the OEM holes in the module ) to the lip ( where it's not visible with the hood closed ) ..... this location provides plug & play ... just in-plug old and plug in new and it's ready to go ..... Option " B" is to have the Module ....DIS-CONNECTED from the system .... JC Thorne can explain it, or Joel-the- Biker ......... good luck ........... PS the new location has NOT caused any issues ..... Mike
    Feb 2013
    Edinburg, TX
    Post
    You CAN get a warranty if desired. It wouldn't be a B.E.S.T. warranty, and might cost a bit more. Friend-o-mine just bought a 2011 RT from our dealer, and was able to buy a warranty for it, but I don't know the details.
    When I traded up to my NEW machine, I bought a non-B.E.S.T. warranty for roughly an equal price. I chose it because it's cancelable/refundable whenever I might trade again. Instead of being stuck with losing any unused portion of the B.E.S.T. warranty.
    NEW - 2015 RT Limited SE6 Intense Red Pearl - 07/21/15
    Retained the old mirrors with TricLed Signals
    General Altimax RT43 rear tire (at...17,000 miles) Ran for 36,500 miles
    Michelin Defender.......rear tire (at...53,500 miles) Ran for 60,700 miles
    Riken Raptor HR.........rear tire (at 114,200 miles)
    Vredestein Quatrac 5 front tires (at 70,500 miles, first new fronts!)
    Gear Brake Decelerometer Module
    OLD - 2012 RT Limited SE5 Pearl White - 01/31/13 - Traded in at 32,600 miles.
    BajaRon Anti-sway Bar
    Kumho ECSTA AST rear tire (at 14,200 miles)
    TricLed Turn Signals in Mirrors
    2015 Limited , Intense Red Pearl
    Jun 2013
    New Jersey
    I purchased my 2014 RTL in March of 2015 and it came with a 3 year warranty (expires 4/30/18). If you are purchasing from a dealer they should be able to tell you if it's still under warranty, if not try calling BEST at 866-477-1415 with the VIN to determine if it is still under warranty
    Another option:
    The DESS can be disabled. You just need to find someone with a Master LIcense to play around with BUDS, and a willing attitude.
    There are several of them in here!
    Sep 2013
    Houston
    Another option:
    This would be my first choice......Just disable the dumb thing.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Sep 2013
    Houston
    Quote Originally Posted by missouriboy View Post
    Be
    very careful with service plans other than the OEM BEST. They have a very lack luster history of denying claims, filing for bankruptcy and otherwise just separating you from your money with very little return.
    Active Member Major spyder's Avatar
    Jul 2011
    Great Falls, Mt
    Default My 2014 is for sale
    Quote Originally Posted by SpyderAnn01 View Post
    Howard
    see my post today
    971-645-0655
    Very Active Member KX5062's Avatar
    Aug 2012
    Central Coast, CA
    I have a very early production 2014 RT and couldn't be happier with it. It has (so far) very trouble-free with about 35k miles on it. I wouldn't be overly concerned about the lack of warranty, I'd be more concerned about a good shop near you should work be necessary.
    2020 RTL SE6
