Results 1 to 21 of 21
    Active Member MNBK's Avatar
    Mar 2017
    Circle Pines, MN
    Default Rear shock air pressure
    So I have looked thru the owners manual for a chart or some info for how much air should be in the rear shock. I have a 2016 F3T and I go about 230 lbs. I am a solo riders since my wife has a 2010 RTS. Am I missing the info in the book?
    Thanks for any info you can provide.
    dave....
    Bryant, Arkansas
    don't go over 70 lbs.
    you might want to try 35 as a starter, don't use a high pressure inflator.
    Cruzr Joe
    Harrington, Australia
    I have seen it somewhere, but can't remember where, Dave.....I will try to hit my "total recall" button, but in the meantime, Cruzr Joe's advice is pretty spot on. I run at 50psi for my 310 lbs and it works well for me.
    HeliBars Handlebars
    Kenda Kanine rear.
    Invalid Emails
    Aug 2010
    Guelph,Ontario,Canada
    Quote Originally Posted by MNBK View Post
    dave....
    I have F3 Limited 2016 Triple Black series.
    remove the passenger seat and look for sticker near air valve. or go to page 51 of your manual
    according to manual you need to put about 40psi in the air shock.
    I run my rear shock at about 38psi.
    Mar 2017
    Circle Pines, MN
    Thanks for the info. I will look again at page 51. The sticker near the valve for the shock is not making any sense to me, but that's not saying much in my case. I probably won't be riding much for a couple of weeks. I got kicked in the knee by a cow at the farm ( oldest son and family are on it. My wife grew up there.) The cow was probably mad that I sold my Kaw(asaki) and went to the Syder.
    Just sayin ya know
    dave....
    Mar 2017
    Minnesota
    Those air bags are really fussy! I run mine about 55psi (2up). I purchased one of those little air pumps from LaMonster and I run it up to 60psi cause by the time I get the air pump off I have lost about 5 psi. I also just trust it is correct cause it seems if I check it it loses air.
    Quote Originally Posted by I-Day View Post
    Just use the pump to check the air, I-Day, rather than a gauge. That way if it does need air you can pop it straight in......better yet, get FOBO...
    HeliBars Handlebars
    Kenda Kanine rear.
    Mar 2017
    Minnesota
    i just put FOBO's on. Love them!
    Great, I-Day! Have you had them on long enough to work out how much psi you lose in a fortnight or so?
    HeliBars Handlebars
    Kenda Kanine rear.
    Mar 2017
    Minnesota
    Not sure what you mean?
    Are you losing any pressure out of your rear shock from week to week, and if so, how much?
    HeliBars Handlebars
    Kenda Kanine rear.
    Apr 2017
    Enfield, CT
    2016 F3 Limited here. How much do these leave the factory with pressurewise? Seems ok riding solo but with the wife it bottoms out every once in a while. Its in the shop getting an alignment done or i would just go check myself.
    Just curious as to how much i should add for roughly 350 lbs of riders
    Those of you with the ACS are getting hung up on air pressures...
    Once you find the ACS setting that gives you the best ride (comfort, handling, and load capacity taken into account): just leave things alone, and it'll happily take care of itself.
    Invalid Emails
    Oct 2013
    Dardenne Prairie, MO
    There is a label under the seat of my 2014 RT that shows settings based on rider and passenger weights. That might help.
    2014 RTSS , Cogna/ black
    Can you take a picture of it, and post it in here?
    Aug 2016
    Kentucky
    Also in your owner's manual.
    Bob
    Sep 2020
    Montreal, Canada
    �� ��. Thank-You
    Aug 2008
    MA & NH
    Cruzr Joe
    Fills fast !
    Feb 2018
    NorEastern, Washington
    dave....
    dave...
    For an F3T the manual and sticker under passenger seat say 10psi min. - 70psi max. Also gives psi recommendations for weight. At 250LBS, I like to run at 15psi for one up and 60-70 psi for 2 up and more.
    Never run less than 10psi.
    Regards,
    Don
    2017 F3T , Triple Black
    Aug 2019
    southwest oHIo
    I don't know all the features of the various models, so I will have to ask: the O/P has a 2016 F3T. Does that have ACS?
    I am guessing it doesn't, because a lot of the responders have F3s or F3Ts in their signatures or say what pressures they use.
    HER ride:
    2017 RT-S SE6 Pearl White
    My rides:
    2000 Honda GL1500SE
    1980 Suzuki GS850G
    Durham,Maine
    2017!!! Found it Peter!!!!!!
    2012 RTL , Pearl
