1330 Cam Sensor
Anybody tackled this yet? Looks pretty straightforward to me.
Cam Sensor ordered. We will see what we will see!
SpyderLovers Sponsor
Easy
On our Alaska trip, Dave had one fail. Went to the dealer, none in stock. There was a motor on a stand as a display, and the tech boosted that one, put it on Dave's bike, and off we went!!
Joe Meyer
I was hoping that BUDS wouldn't need hooked up just to replace the sensor. Buddy has a '16 F3T with that problem. If this works, I will order one to leave in the on byke tools. Same sensor fits every 1330, so it will be a spare for both bykes.
Just out curiosity what "error code" comes up, so I know what to look out for.
Chris
Chris
Spyder Diagnostic Codes - P0340
Error on camshaft
position sensor signal
Disconnected sensor
Blown fuse
Defective CAPS,
damaged circuit wires,
damaged connector or
damaged ECM output pins.
Trigger wheel missing
or in incorrect position
on intake camshaft
Make sure sensor
connector is fully inserted.
Measure voltage between
harness connector CAPS-3
and ground (expected
value: 11 to 13 volts).
Measure resistance from
connector: ECMA-E2 to CAPS-2
(expected value: < 2 ohms).
connector: ECMA-D4 to CAPS-1
We should have it in a couple of days. We will see then.
Too bad you guys weren't aware of having to use B.U.D.S. for calibration when that part was replaced. It would have saved a lot of time on this thread. At least we know now what is required.
16 F3T cam position sensor replaced; No B.U.D.S Required and all is good
101_0015.jpgWifes F3T got the Limp Home Screen a little over a week ago, and when she got home (35 miles commute) pulled up the PO340 code - bad camshaft position sensor. Did search on computer and saw this thread so we check 3 dealers and scheduled an appointment the earliest was 3 weeks out. Since my wife loves her commute on the F3 she was not a happy camper! Also we had several trips planned, and this was adding to the discord. To paraphrase- Unhappy Wife: Unhappy Life!!
Anticipating that the BUDS calibration would be needed and that the part would have to be ordered anyway, we stewed, but ordered the part anyway from our local dealer, and hoped that the diagnosis and repair would go smooth. We like the local tech and didn't want to "LIMP" the hundred plus miles to Denver and maybe still be waiting on a fix.
Parts man Ashton, called Tuesday and said the cam sensor was in along with the Oring I ordered just in case. Turns out the sensor comes with an ORing in place, so that was not needed. I talked with Service Manager and Tech Isaac, and he said try the sensor, and if the PO 340 Code doesn't go away, they would try to fit me in for a BUDS hookup to resolve the full diagnostic report.
It took me about an hour to wiggle the little sensor out of the recess in upper rear right side of engine, but was able to get the new one in and snapped in place. Fired the F3T up and eased down the drive with the Limp Mode showing for about 10 seconds and then IT WENT AWAY, and my 2 mile test ride was free of codes and running smooth. My wife rode to work today, so if she rolls in this evening with a smile on her face we are good to go on our planned rides this fall. Shout out to Ashton, Desmond and Isaac at Fremont Motorsports for their communication and help!!
07 Shadows, Aero, Spirit gone but not forgotten
03 Harley Sportster, 07 RK moved on
11 RT- 76,000 mi, 15 RT-S- 44,000 mi, traded for current 15 base RT and 16 F3T
Hope you have better luck than we did. Since it was a short in the battery that caused my customers P0340, you may not have to clear it with BUDS. We tried everything we could to clear the code and wouldn't. Different circumstances = different result?
Glad I found this thread. I'm having the same issue.
Cam sensor
Doc would you please post the part number for the cam sensor for the 1330 engine and where you obtained it.
http://www.cheapcycleparts.com/oempa...40/valve-train
Item #28. Same part all 1330's, all years.
Item 29 you mean? Comes with a new o ring?
The Critter 2016 RT-S
Cat Bypass from Lamonster
BajaRon Sway Bar
Hella dual horns with relay
BRP Hitch with trailer module
Foam Grips
Adjustable Air Deflectors
Shorty antenna
Ultraguard half cover
Gremlin bell from my son
Sorry, yeah #29. Not sure about the O ring. Should be getting it in the net day or two....
