Results 1 to 9 of 9
Thread: rear tire
    Apr 2015
    tacoma wa.
    Default rear tire
    will this car tire work on an 2010 RT "P235/75R15 "
    Very Active Member SPYD3R's Avatar
    Apr 2011
    GREENVILLE, SC
    Default 2 tall
    i have a feeling you'll bottom out, tire hitting the under-sides of you SPYD3R, since a series 75 is much taller than the OEM series 50....
    look here: https://www.tacomaworld.com/tirecalc
    Dan P
    SPYD3R
    Nov 2012
    North Las Vegas, NV
    WE had a 2012 RT and the 215/60/15 size worked well for 23,000 miles.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Apr 2015
    tacoma wa.
    Default rear tire
    some of the other post recommend Yokohama S Drive 205-55-15
    and it looks good or am i looking at this wrong
    Dec 2013
    I'm running a 225/60R15 & I really doubt you'd get anything either wider or taller in there, let alone something both wider AND taller, ie with a higher profile, under the rear of any Spyder, at least not without doing some work....
    Might be interesting to see exactly what was needed to get one to fit, tho?!?
    Default THIS TIRE
    Quote Originally Posted by clayw View Post
    ........ Considering ALL the really great 215/60-15 tires that will work .........WHY are you even considering this ????????????? ............... Mike ............ Even if you gave me this tire for FREE , I wouldn't attempt to put it on.
    Apr 2014
    Beloit Kansas
    Oh, it will work.....Like a butterknife through a steak.
    Default BUTTERKNIFE
    Quote Originally Posted by 4 MARIE View Post
    ........... Well I'd put my money on the Butterknife ......... Mike
    Nov 2012
    Pueblo Colorado
    Default 2" taller tire with 20% greater circ than OEM?
    Quote Originally Posted by SPYD3R View Post
    Dan P
    SPYD3R
    I would be surprised if it fit or that nanny would like it. If anyone wants to try, let us know how it went.
    2015 RT , OEM Black Gloss
Tags for this Thread
