Results 1 to 16 of 16
    Very Active Member BigGuy66's Avatar
    Aug 2016
    North Central Indiana - WInona Lake, IN
    Default There must be a better way....
    ... to attach a mirror so I can see around my Bunkhouse trailer. I just know someone on this site knows more than me about how to solve my "can't-see-around-trailer-with-regular-Spyder-mirrors problem.
    Jim
    Ryde, eat, sleep.... repeat
    2019 Spyder RT Limited Pearl White/Dark
    LaMonster drink holder with X-Grip
    LaMonster Belt Dampener
    Lamonster USB cable with extension
    Variously called Stormtrooper, Pearl, and Goober by wife and various (friends?)
    Invalid Emails
    Oct 2015
    morgantown west virginia
    Quote Originally Posted by BigGuy66 View Post
    Jim
    UH-OH, you been watching Red Green on PBS!
    May 2011
    Carrizozo, New Mexico
    I tow my Mini Trailer by USA, a sponsor on this site, with just the regular mirrors, no problems. Try talking with Ann Meyer she has over 100,000 miles with most towing a trailer.
    Ann can steer you in the right direction!
    Have you considered using a rearview camera?
    Very Active Member IGETAROUND's Avatar
    Oct 2011
    Kalamazoo, Mi
    Default there must be a better way
    get what ever type or style bar end mirrors you want, go to the Ace hardware store nearest you with the mirror and it's attachment base and replace the attachment allen head screw that currently holds on the handle bar end cap with a longer stainless steel screw and attach your mirrors to the ends of your bars. You might also need some plastic inserts to properly size the inside of the attachment bracket on the mirrors.
    When your all done you should be able to see around your bunkhouse trailer quite nicely.
    Ann uses her stock RT mirrors as far as I know.
    Good shopping
    Al
    All the great movements in the world began with a cup of coffee!
    2018 F3-T
    My mods: Can am Trailer hitch, USB and 12 volt power outlets, Gustason windshield, Bead rider seat cushion, battery harness for electric gear and battery tender, Time out trailer.
    2018 F3-T , Pearl White
    Aug 2016
    First - I didn't really try to ryde towing my trailer with that mirror duct taped to the handlebar... it was just an easy way to show what I needed. Second - Thanks for the leads about what to do about seeing around my trailer. I knew there was help out there! Third - how do I find Ann Meyer. I did a search, I looked at the member list but those are screen names, so I 'm not sure how to talk with her about trailering. Thanks -
    Jim
    Jun 2010
    Las Vegas
    Hey BigGuy I'm the Ann you're looking for. Your bunkhouse must be wider than a RT-622 or considerably taller because I have no problems seeing around mine. My stock mirrors do the job.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Aug 2016
    Quote Originally Posted by SpyderAnn01 View Post
    Thanks Ann - Yes, the Bunkhouse is a Queen-sized trailer and is just tall enough that I can't easily see around it. So - I'll try to find just the right mirrors to use when I'm pulling that camper.
    Jim
    Dec 2013
    I've got a set of those 'grip the top & bottom edge of your OE Mirror' towing mirrors with stretchy rubber straps that make them grip the std mirror & just put them on the std RT Mirrors - altho admittedly I have the Magic Mirror Mounts so my OE RT Mirrors don't vibrate at all & even with the std widthe extn mirrors the Magics hold them on securely!
    Not sure I'd try using them if I didn't have the Magics tho, the OE mounts aren't really up to it!!
    Active Member nslowmotion's Avatar
    May 2015
    https://t.me/pump_upp
    Default Cant see
    I had the same problem when I bought my aspen classic camper. I bought the dash mount kit from JT and added 6 inch ram mount extensions to it and put ram mount mirrors on it. Now I can see over and around the camper. Perfect. Plus I just pull it off when I am not towing, takes about 30 seconds.
    Jul 2016
    Grove City, Ohio
    Tricled is launching new mirrors for a wider angle view that attach over your current mirrors. Contact reggy to ask him about them. May be better option.
    Jim
    Invalid Emails
    Feb 2016
    Dublin, OH
    Default New convex mirror - coming soon from TricLED
    Jim
    Hello, we have new product coming up soon (this week?) that will remedy this issue.. convex mirror for RT.
    Aug 2016
    Quote Originally Posted by Cindy-TricLED View Post
    Will you have these mirrors at Spyderfest? I'm interested....
    Jim
    Aug 2016
    Quote Originally Posted by nslowmotion View Post
    Do you have some details for your mirrors so I can see what you are talking about? How about a pic or two? Need to see!!
    Jim
    Invalid Emails
    Feb 2016
    Dublin, OH
    Jim
    BigGuy66, once we have the product launch, I will post picture
    Jul 2010
    Las Vegas, NV
    Default Interim fix
    Put convex mirrors on your fenders. At least you can see enough to know if you need to turn your head!
    Joe Meyer
