Results 1 to 8 of 8
Thread: wont start
    Apr 2015
    tacoma wa.
    Default wont start
    I replaced the battery in my 2010 rt the cables are tight on the battery but when I try to start it sounds like a loose connection click but not trying to start I am lost now any one help
    Very Active Member bruiser's Avatar
    Eastern North Carolina
    what are the panel lights doing? are they flickering or going out? Did you check the kill switch?
    USAF '69-'89 E7
    Thailand/Vietnam 1972
    Apr 2015
    tacoma wa.
    Default dish light
    the light go out and recycle i can hear a noise like a elect motor running also a vietnam vet army 1965 1966
    Jul 2011
    Mitchell, Ontario, Canada
    Check the jumper posts under the seat and see if they are tight. Warning DO NOT LOOSEN THE NEGATIVE ONE. If they are tight. Get a set of booster cables and start it that way. If that works. You installed a dead or bad battery.
    2018 F3 LIMITED
    A gentle reminder...
    Posting a question in multiple areas of the forum only makes it tougher for you to find where a useful answer has been left for you. It's best to post it in just one place, and watch for the results...
    Good Luck!
    Default Dupe....
    check both your posts....
    ​2012 RS sm5
    Apr 2015
    tacoma wa.
    Default started ok
    the battery I bought was bad had to return it and replaced now all is good thanks
    Jul 2010
    Las Vegas, NV
    Default Happens
    Glad you figured it out.😀
    Joe Meyer
Tags for this Thread
