Results 1 to 11 of 11
    Apr 2017
    Lutz, FL
    Default RT Accessory Mode Discovery
    Hey, you guys might already know this trick, but I found this out today while cleaning my 2016 RT. I had the key on listening to music through my GPS. I turned the key off not to waste the battery and accidentally touched the Mode button. All the lights shut off except for the backup lights and the radio kept playing. I tried it again and it worked. The screen flashed to a blank screen then the radio came on, my GPS /MP3 played through the speakers, but no running lights were on.
    When the key is on, turn it to off while holding the Mode/Eco button. To clear it turn the key to on and then off again. Not sure if this works with other years or models. But it’s a nice way to conserve battery life without running all the lights.
    If you guys have any other quick tips please list it or guide me to the magic. Go try it, Go, Go, GO!!!
    Stevie
    Per Copperman: Another way to turn off the accessory mode is to turn your 4-way flashers on for a second and then turn them off. Thank you! Stevie
    Mar 2013
    Maumelle, AR
    2020 RT Limited , Chalk
    Apr 2017
    Lutz, FL
    That's awesome thank you!
    Quote Originally Posted by Copperman View Post
    Jul 2011
    Mitchell, Ontario, Canada
    It's on page 39 of your operator's guide.
    Default Agree...
    the manual is full of stuff if you read it from cover to cover....but then it is more fun to find things by accident....
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    x 3. And, I did not catch that trick.
    Nov 2015
    Myerstown, Pennsylvania
    I was just using accessory mode over the weekend & found just pushing & holding the mode button will also turn off accessory mode. Ryde safe!!!
    The Critter 2016 RT-S
    Cat Bypass from Lamonster
    BajaRon Sway Bar
    Hella dual horns with relay
    BRP Hitch with trailer module
    Foam Grips
    Adjustable Air Deflectors
    Shorty antenna
    Ultraguard half cover
    Gremlin bell from my son
    Active Member doncanfix2's Avatar
    Aug 2019
    MD
    I've tried this a number of ways and it doesn't work on my 2018 RTL, currently loaded with software version 20.80:
    -- engine running (or not), holding Mode and then switching off and continuing to hold mode -nothing
    -- engine running (or not), switching off and then immediately pressing and holding mode - nothing, etc.)
    Does anyone know for a fact this works on the stated model year/SW version? Alternatively, is there a different method?
    2018 RT Limited , OXFORD BLUE METALLIC Dark Edition
    Jul 2011
    Quote Originally Posted by doncanfix2 View Post
    Only for 2017 and earlier models.
    Oct 2021
    Pennsylvania
    2021 F3 Limited, I tried pushing everything and nothing works to keep the radio playing.
    Quote Originally Posted by 3Wheeled View Post
    As Billybovine mentioned back in September 2021 in the post immediately above yours 3Wheeled, the method discussed in this thread works....
    Sorry, but them's the breaks!
Tags for this Thread
