I pod camper
Has anyone tried towing an Ipod camper by Little Guy Trailers. Says it weighs 645# with a 70# tongue weight. I think its to heavy for my 2014 RT Limited.
The issue isn't towing that heavy a trailer, the issue is stopping that heavy a trailer.
That's why BRP has a 400 pound weight limit.
probably pull it ok but stopping it is another thing, does it have trailer brakes.
BRP says 400 lbs
I have been looking at this for a while.
http://www.clcboats.com/shop/boats/r...p-trailer.html
While the total weight with typical outfitting is close to the Little Guy it is a home built and I would be willing to bet if you were careful you could keep it under 450#.
How much does the CLC Teardrop Camper weigh?
About 250 pounds fully outfitted and accessorized. The basic shell and galley weighed 176lbs on our digital scale. Trailer weight will vary wildly; our aluminum Trailex trailer weighs 196lbs. Figure on a total of 500-600lbs all-up with typical outfitting.
All of the above
adding that the tongue weight is also over the recommended weight....keep looking there are many out there that would be better suited...
2012 RS sm5
WELLLLLLL NOW THAT YOU MENTION IT
I've posted this info on other threads about the " teardrop " style camper...... On the above kit - if you swapped out the Marine plywood ( very heavy ) for a similar strength " COROPLAST " product , you could save 75% of the weight without sacrificing anything..... google " coroplast " and see what they have, I was amazed at the variety of products .... they build entire HUGH greenhouses with this stuff ................. Mike
CORRECT PRODUCT NAME
