Results 1 to 14 of 14
    Member Docbilly's Avatar
    Apr 2016
    Kelseyville, Ca.
    Default 2015 F3 fender mount broke
    Riding home from work and I look down at the left side and the mud flap side of the fender is shimmying back and forth in the wind. Pulled over and my fender is not attached anymore. I got home and pulled it off and the molded plastic mount just broke off. Seems like a really flimsy design. Not sure if I can super glue and silicone the plastic part back on or not yet. For now, I removed the other front fender too and I'm going open wheel. I was wondering if anyone else had this problem?
    Bossier LoUiSiAna
    Is open wheel even legal? Know you need reflectors minimum to show how wide you are on road The fenders are not just decoration they are there to keep the road junk from being thrown up at you or others
    Active Member papanorm's Avatar
    Aug 2016
    central texas
    I would check with your dealer to determine if it is a warranty replacement.
    2016 F3L , Big Bike Parts Black
    Very Active Member zuni's Avatar
    Mar 2014
    JAX FL
    Hopefully it is warranty. What style do you have? I don't see the screws that secure the upper ridge with reflectors so I'm guessing yours has the single groove running down the middle. if it does have the upper piece you could run a couple of screws/bolts down from the top to secure it as they would be hidden.
    CJ JAX
    Apr 2016
    Kelseyville, Ca.
    No I don't believe it is legal. I believe the vehicle code says any vehicle with three or more wheels must have fenders. So I guess if you have a motorcycle with two wheels you can have a bobber no problem.
    Apr 2016
    Kelseyville, Ca.
    Quote Originally Posted by zuni View Post
    CJ JAX
    It does have a single groove down the center so fashioning my own bracket would be pretty ugly. I'm going to try using crazy glue and then silicone around the area where broke trying to strengthen it.
    Dec 2016
    Somewhere USA
    Quote Originally Posted by Docbilly View Post
    Be prepared to be covered in muck.
    Very Active Member YPILOT's Avatar
    Aug 2009
    Johnson City,Tennessee
    Hey Docbilly, I don't know if the superglue will hold that, I believe a better option would be J.B. Weld for plastic. Clean the area really good and mix your 2 ingredients together. works like bondo and you can reinforce weak areas. When it hardens it will be strong. Dennis
    "Stupid is as Stupid does"
    Don't Drink and Drive or Ryde!
    Each Day is a Gift
    Very Active Member GaryTheBadger's Avatar
    Jan 2009
    Northwest Arkansas
    Ditto the J B Weld recommendation.
    Enjoying now: 2015 Spyder F3 SE6, 1970 Indian MM-5A, 1972 Suzuki RV90J Rover, 2017 Indian Chieftain (wife's)
    Wish-I-had-kept-them: 2008 Spyder GS SE-5, 1967 Shelby GT500 w/Paxton supercharger, 1972 DeTomaso Pantera, 1991, 1992 & 2001 Acura NSX's, 2012 V-Star 950 Tourer, various 2-, 3- and 4-wheelers
    2015 F3 SE6 , White - The fastest color!
    Apr 2016
    Kelseyville, Ca.
    Quote Originally Posted by YPILOT View Post
    Good of thinking on the jb weld. Thank you!
    Very Active Member vondalyn's Avatar
    Jun 2012
    Longmont, CO
    Default should be under warrenty
    I would also check with the dealership to see if it's under warrenty... you may not have to do anything (unless of course you'd rather...).
    We now have His and Hers Spyders!
    Current Spyder: White 2015 F3-S SE6
    His Spyder: White 2015 F3 SE6
    Previous Spyder: 2012 RT Limited SE5 -- 30,300 miles
    Previous rides: Kawasaki & Honda
    2015 F3 , Pearl White
    Feb 2009
    Ceresco, Michigan
    WOW... first I've seen this on an F3. I would for sure do a warranty claim if you can.... shouldn't break like that!
    I've seen many others ride without front fenders.... doubt you'll get in any trouble.. but for sure will get some dirt and rain on you.
    Apr 2016
    Kelseyville, Ca.
    So here's the update...
    i picked up jb weld specifically made for plastic. Cleaned the area and used the jb weld to glue the mount back on. Worked perfectly!
    Thanks for the suggestions all.
    ride on !
    Very Active Member Warlock's Avatar
    Oct 2011
    Magnolia, Ms
    ride on !
    Sounds like someone could have sat on it or jerked on it. Got some messed up people out there now.
    David
