Seen it I think..
I have the ST SE5 2013 and I was reading here in the forums that they received free body parts changed for free due to heating issues. I call the local show and they are stating with my serial number the only recall is something with the brakes? They are going to replace the part for free but there is no mention of change of the plastic to cool off the engine? Anyone know anything about this issue?
Fyi it was not a recal but a option for 2014 panels on the 2013 : parts are sure to be slim if they even still offer. Dont feel bad I still have my 13panels on too will have to find replacement decals if i can update
http://www.spyderlovers.com/forums/s...98#post1237498
Cooling your Spyder!
The original "Cooling Kit" was for the 2013 RT. It seems it got hot enough to burn some skin & actually burnt up some Spyders! You can order the scoops direct from BRP or your dealer and install them yourself. I'm in the process of doing mine right now. When I questioned others on here about them I got some replies about removing some lower, as in underbody panels. I guess the deal is "More Air in with the scoops cooling the engine compartment" , the more air, hopefully out and not too much Drag from main body. I think the lwer panels are called the "belly pan"!
Cost ?
Originally Posted by ingramwc
The swap out of the 2013 ST side panels for 2014 ST side panels is NOT a recall!!!! It is a Goodwill bulletin from BRP. An authorized BRP/ Spyder dealer has to call BRP to order replacement panels, it takes 2 weeks approximately to get the parts. This a no charge to the Spyder owner, and BRP allows a labor charge to the dealer.
I had mine done, biggest problem I had was educating the dealer about the problem and getting the correct parts ordered. There is a recall for RT models to install air intake vents,
but that is only for RT models, do not confuse the two. They are very different issues. Good luck, and try to get it done, as the weather gets hotter, you will be glad you did!!!
How much did this cost you ??
Stated NO COST TO THE SPYDER OWNER. I had this done a year ago. Dealer would not install so I took them home and did it myself. Only took about 45 minutes for the whole job.
I agree!
I'm jumping in here kind of late. I bought my 2013 STL in 2015. When I asked the dealer about the heat issue, he dug up the bulletin and read it to me. It even included the dealership sending panels to a paint shop to have the color matched if the 2013 color was no longer made.
My dealership had the parts within a few days and called me to schedule. It took them about 2 hours. Probably that long because they had to apply the decals on the new parts.
I would recommend jumping on it ASAP.
All the best,
John
2022 RT Limited
- Garmin XT (I would be lost without it)
Driving Lights (Very bright to improve my sight)
Floorboard Lights and Turn Signals (I like to be seen)
Passenger Armrests (So my wife doesn't fall off)
Trailer Hitch (So we can bring more stuff with us)
Chrome Wheels (Because the beautiful stock wheels just weren't good enough)
Front Fender Sequential Reflector Lights (I was wondering what to do with my paycheck)
They were pretty slow in doing it then. 2 HOURS. I did it in less time than that at home and that included installing the two decals that needed to be put on.
Cooling Kits
The cooling kit was for the 2013 RT. I'm not sure if this issue also applies to the 2012 RT-SE5. Was there a part number for the kit, and do you recall how much it cost you?
