2012 Spyder rt - Turn the key and nothing at all happens
Help ! the sun is out and I took a short test ride, came home and packed for the day. got on and turned the key and noting happens at all. No lights, no noise, no nothing. Battery has been on charge all winter, terminals are tight. Any Ideas??????
first thing I would do is remove the battery cables and clean the terminals. then spray some battery anti corrosion on them.
Check your fuses and relays. Are any fuses burnt out? Are the relay fully seated in their socket?
2018 F3 LIMITED
Qriginal battery? If so, it's toast.
Sent from my SM-T350 using Tapatalk
2014 Copper RTS
thanks
It is the original battery, it tested good, there is power to the leads (metered) and I rode it 10 miles just prior to this problem
thanks
I have not checked that I was thinking there was a fuseable link somewhere in the line
No fuseable links used in a Spyder. Just fuses.
2018 F3 LIMITED
Going fuse hunting - I'll let you all know , thanks for the fast reply's!
There are 2 fuse boxes to check. On a 2012 RT, I think the mains are under the seat.
2018 F3 LIMITED
Try jumping it, if it starts it's a bad battery.
Agree...
One more for hooking up to another power source. This will show if you have a good connection to the system and the battery is the issue...When you say connected to the charger, it that a maintainer or other charger trickle type..?? many will give you a good surface charge with maybe one good start and them nothing left. Let us know what you find as you trace on back in the system....
2012 RS sm5
OK This is what I have
I checked all the fuses, good I took the visible terminals off cleaned with a tooth brush and electric clean. I hit the horn accidently and there was a very faint click. I hooked up my Shop jumper battery again and this time everything came to life. But still have no juice from the charged machines battery. So I'm off to figure out how to get at the battery &^*%%, it does not look simple
Thanks for all your help, this is a great forum!
SpyderLovers Sponsor
BATTERY
You had enough power to fire it up once, and that was the end of it. new battery time don't get a cheap one replace your battery every two years maybe three even if you think it's good and you won't have this problem
battery swap is easy. remove the left side panel and the black plastic panel under left side of seat. all there is to it. and when you change it use the star washers on the bolts. I call them alligator washers.
It's bad. A battery can still have power but if its output drops under 10.5 volts it won't work in a Spyder.
2014 Copper RTS
If you cleaned the visible terminals & are now moaning about finding & getting battery out, you can't have cleaned & tightened the actual battery terminals
2008 GS SM5, Full Moon Silver
2007 Piaggio MP3 - 250cc
Check your charger also. I have no less than 10 chargers and maintainers operating all the time. One of the maintainers quit working but the lights were indicating it was working but actually was dead, putting out nothing and battery ran down. Also changing battery is simple, follow Bob Finless video and you will have no problem. Took me 30 minutes on a 2012 RTL. Replace with a Yuasa as others have indicated, it is what it comes with.
Roger
2012 RT Limited
Vertika Floor boards
Painted rear fender & dash
Carbon fiber panels
Utopia back rest
Baker air wings
Elka shocks and relocaters
CB radio
ISO hand grips
Tric LED fender light
Turn signal lights in mirrors
This is should help :-
https://youtu.be/aCsNYNU6eYo
Thanks to Finless Bob
Found some other videos
https://youtu.be/xNe09_ii7uI
https://youtu.be/F-QKaanJDmE
Eddie Sheppard
Poole Dorset UK
Get a Spyder - See the World
Yes I had only cleaned the visible leads , now that the panel is off, I can't believe how dirty it is in there. Any ideas on the best way to clean it out? Air is not doing that great a job. Pressure washer?
take a photo
if yo can take a photo of what the area looks like for the next person who has this problem , { if you can that is } I think the idea when you have the battery charged , and cycle running , turn on every thing , lights on high , flashers , any thing with electric , look at the volt meter , if it is staying in the good zone on charge , the system is working too the battery , if everything shuts down ---- well , lets start there { any one every mess with the mag charger ? } magneto < --- think that is how we might spell it ?
Were the terminals loose, corroded etc?
Never had to clean the battery compartment but maybe a rubber glove & a hot soapy rag to start with.
