Page 1 of 2 12 LastLast
Results 1 to 25 of 27
    Active Member Many brands's Avatar
    Aug 2016
    Atwater, California
    Default Air In - Frustration out.
    Just arrived, and just tested. This Air Chuck is adjustable in any and all directions, and makes getting air into the rear tire - so easy.
    Very Active Member Warlock's Avatar
    Oct 2011
    Magnolia, Ms
    This is what I use. Works great. http://getagage.com/accessories.cfm
    David
    May 2014
    Beaverton, Oregon
    Hi Many brands,
    Re: makes getting air into the rear tire - so easy.
    Last week I used my newly-purchased Lamonster-Approved Air Pack. It took a minute or two or three to get it on the rear tire valve. But that Lamonster-Approved device is one sweet way to inflate tires. I'm sticking with it.
    Jerry Baumchen
    PS) One thing I don't care for with the Air Pack is that it is easy to change the values; from PSI to Atmospheres, etc. Once I learned to keep my fingers off of 'that' switch, it was easy to understand & use.
    Oct 2011
    Magnolia, Ms
    Quote Originally Posted by JerryB View Post
    Hi Many brands,
    Jerry Baumchen
    I like that. Will see if he has some at Spyderfest.
    David
    Very Active Member Bensonoid's Avatar
    May 2014
    Benson, NY
    Quote Originally Posted by Many brands View Post
    And it looks cool too. Thanks for sharing.
    2015 RTS Special Series
    Russell Day Long seat
    F4 Customs windshield
    Sena 20s
    Very Active Member 2Paw's Avatar
    Feb 2013
    USA, Texas, Mckinney
    Where did you purchase this? Can you post a link?
    Ed
    They told me not to give up on my dreams, so I went back to sleep.
    Champagne 2017 RTS SE6
    Quantum Blue 2012 RTS-SE5 "Bluebell, Bell for short" - Traded 09/2017
    Very Active Member irvin48's Avatar
    May 2016
    mt morris il
    says dennis kirk in the picture. hope that helps.--irv
    2015 rts-white pearl- mods- '16 F3 fat 6 chrome wheels,
    and some little stuff. setback utopia backrest, baja ron
    sway bar, oem adj. air deflectors, marlin gps compass,
    lamonster fbb foot pegs[modified brackets], lamonts
    vibration damper, rock guard, and side case stiffener kit,
    . brp comfort seat. , fomozas and
    altimax, magic mirror mts, and wide mirrors.
    [joyce & irvin toms]
    Hi Many brands,
    It's a pretty sweet rig!
    (It even works well on that pesky rear tire valve...)
    Aug 2013
    Northern California
    Default Yep
    Hi Many brands,
    Jerry Baumchen
    The Lamonster device is super easy on the rear tire, especially if the valve stem is in the right spot. Jerry my first time on the RT took some finagling, but the second time was seconds. The F3 is a piece of cake. Love this device!
    Aug 2013
    Northern California
    Quote Originally Posted by Warlock View Post
    David
    Why wait. You can have it in two days.
    MOgang Member xpeschon's Avatar
    Mar 2009
    Waynesville MO
    Quote Originally Posted by 2Paw View Post
    https://www.amazon.com/Motion-Pro-Ch...ords=Air+Chuck
    Quote Originally Posted by Pirate looks at -- View Post
    It's such a good product, that there's no reason to wait for it!
    Active Member Spyderjuice's Avatar
    Aug 2008
    High Point, North Carolina
    Default Lamonster's
    It is a very nice piece and works as advertised. However, I can't seem to un-screw the cap from the valve stem before a couple of pounds of air is lost. I guess I'm not very fast. It needs a clamp on piece instead of a screw on IMHO.
    What's the secret? Is there a fitting that would screw on the end of the little tube that converts it to a straight clamp on.
    Stan
    Happy owner of 2014 White RTS - SE6
    I don't know how to stop that air loss; it was my biggest worry as well...
    Perhaps some practice with will help!
    (Or a pair of "handier" hands! )
    I found that the air loss was less than a pound, so I just set the unit to one pound more than I had planned.
    Aug 2007
    Springfield, MO
    Quote Originally Posted by Spyderjuice View Post
    Stan
    The kit now comes with a 90 degree clamp-on and a straight screw-on. The 90 won't work on the rear. You can add more air to compensate for what you lose or just get better at it.
    Aug 2007
    Springfield, MO
    David
    I have good stock now and will then too.
    May 2014
    Beaverton, Oregon
    Hi Lamont,
    Re: The 90 won't work on the rear.
    The 90* clamp-on worked just fine on the rear for me.
    As I said, it does take a minute or two or three to get used to using it; and positioning the rear valve 'just so.'
    Just sayin',
    Jerry Baumchen
    Aug 2007
    Springfield, MO
    Hi Lamont,
    Just sayin',
    Jerry Baumchen
    I haven't tried it on the RT but the bigger pulley is in the way on the F3. Glad it worked for you.
    Aug 2013
    Northern California
    Default Works Great
    The straight line works easily on the F3L
    Apr 2012
    Northglenn Colorado
    Quote Originally Posted by Lamonster View Post
    I just purchased the Lamoster air pump. It came with 2 hoses but I have yet to figure out a way to get that short hose to the rear tire on my F3. I also cannot figure out how to tell how charge the devices is.
    May 2014
    Beaverton, Oregon
    Hi Lamont,
    Re: Glad it worked for you.
    Hey, that makes two of us.
    Not every product that I buy works as good as this Air Pack does.
    Jerry Baumchen
    Oct 2011
    Magnolia, Ms
    Ya'll made me feel guilty, so I ordered one.
    David
    Spending other peoples' money, and wasting their time: it's what I do bestest!
    You won't regret it!
    But if you do: PM me, and I'll buy it from you!
    Feb 2012
    Spring City,Utah
    Harley has a short air hose extension for use with their Electra Glide Ultras. Put that on the Lamonster compressor and then use that to connect to the valve on the Spyder and you wont lose any air.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Thanks! I'll have to hit the local "Hawg Farm", and see if I can get one!
