Results 1 to 16 of 16
    Jun 2014
    Lowrys SC
    Default Most benefit, muffler or cat bypass?
    I am wanting to do either a cat bypass or muffler on my RT. Not wanting to do anything crazy or loud.....just want to see the opinions on which one would give the most benefit and be worth the money.
    2010 RT Audio and Convience SE5, wider vented windshield, XM radio, digital voltmeter, K&N filter, LED turn signal strips, ISCI floorboards, Lamonster LED Headlights and Fogs, Two Bros Black series
    Active Member SpyderSteveFL's Avatar
    Dec 2015
    South Florida
    That's almost impossible to answer as asked. Most benefit is subjective to each person - sound, performance, etc. and worth the money - well same thing, $20 may be a fortune to one person and another may happily throw down $1000. I think you need to define what you really want and then the cost/benefit is only something you can answer.
    NEW/CURRENT (Wife's Bike, I ride Goldwing/Africa Twin)
    2023 RT Limited Petrol Blue Metallic
    Working on the upgrades... so far... Show Chrome Isolator Fuse Block, Tackform Adventure Wireless charger phone mount
    OLD/TRADED
    2015 RT Limited Intense Red Pearl
    Farkles: Ultimate Tallboy seat, FOBO, JT Dash Mount, Lamonster Spyder Cuff, Kradellock, TricLED lighting - fenders, A-Arms, saddlebags, run/brake, Custom Dynamics high brake light, brake modulator, Drink2Go passenger, MUTH turn signal mirrors, Bajaron sway bar, Kuryakyn ISO grips, SpyderTV front grilles & rear trunk organizer, homemade trunk light
    Pending: Elka shocks, Yokohama S Drive rear tire, EVO 595 front tires, Centramatic balancers, Neutrino black box
    Very Active Member Devious56's Avatar
    Oct 2015
    N.E. Florida
    I've done both, a cat delete to start with which gave me a little more: performance, sound, and gas mileage. I found an exhaust system that PitBull Powersports offers for about half of the others, and I bought it. Now I have more performance, sound, and 45 mpg. For me the big draw back is the sound, it is almost too loud. The best sound I've heard is with an Akropovik muffler and not cat, but that muffler is $1,000.00, too much for my pocket book. Shop around and make up your own mind, try to see other Spyders and get an idea of what's available, and what you are willing to live with.
    How old would you be if you didn't know how old you were?
    Jun 2014
    Lowrys SC
    Quote Originally Posted by SpyderSteveFL View Post
    Well a decent exhaust, Two Bros or Yoshi, is going to be about the same as a cat bypass. So saying the money is equivalent.... Which would give the most benefit for the money? I wouldn't mind a little more sound but nothing loud. Plus if I could get a few more MPG's that would be good too
    Jun 2016
    indpls in
    cat delete
    Registered Users Gallam03's Avatar
    Mar 2017
    Iowa City
    Ive read that doing just the muffler is a waste of your time and money so I did both. The cat is very restrictive and I didn't like the sound with just the cat delete. I'm in for about 700 with the Lamonster cat bypass and 2bros s1r. Adding the two bros gives it more of a deep growl rather than a tinny whine. At least that's what I think it sounds like.
    https://youtu.be/Wz2pFVnBgbo
    Default As I see it...
    They are both restrictive to the flow. I would have to go with the cat being first, creating a lot of heat and being very heavy. The only way to tell is for someone who has done both and that may be hard to find. Not any I know took off the cat, then put it back on to try a pipe. The best would be to take off the cat and later go with a pipe if you like. There was a post recently with audio of RT with stock set up cat removed and pipe added you could search that out and check with him...
    ​2012 RS sm5
    Aug 2013
    Northern California
    Gene is it legal to remove the Cat in California? Any warranty implications???
    Northern Kalifornia
    Default Answer
    No and no.
    Jun 2010
    Las Vegas
    First I put on a Two Bros and didn't see any real benefit. Then I hit the Pitbull Cat/Exhaust combo performance was better and improved gas mileage but it was too loud for me. So I went with a cat bypass and the Two Bros and that was even louder still. I am now running the cat bypass with the stock exhaust and I am finally happy. Gas mileage isn't as good as with the other setups but still much better than with the stock setup.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Active Member RiverCity45's Avatar
    Dec 2016
    Texas
    Quote Originally Posted by Pirate looks at -- View Post
    Appears it is not legal in Texas. Doesn't mean people don't do it anyway.
    https://www.tceq.texas.gov/airqualit...tampering.html
    2012 Spyder RS
    Very Active Member Firefly's Avatar
    Feb 2009
    Ceresco, Michigan
    I agree with others that have gone with the Cat delete... I'd start there and keep the stock pipe and see how you like it.
    Spyder #1 - 2008 GS SM5 Premier Edition #1977. RIP after 80,000 miles.
    Spyder #2 - 2012 RT SM5. Traded in after 24,000 miles.
    Spyder #3 - 2015 F3 SM6. Put 13,000 miles on and sold it.
    Spyder #4 - 2017 F3 SM6. Too good of a deal to pass up!
    Very Active Member M109Dreamer's Avatar
    Mar 2011
    Jackson, MS
    Quote Originally Posted by RiverCity45 View Post
    [emoji23] havent been asked once if the Spyder has a cat and or emmissions info when we get it expected.
    Sent from my SAMSUNG-SM-G920A using Tapatalk
    2007 M109R LE - To many MODS to list. Its cheaper that way!!!
    Apr 2016
    Albany NY
    Cat delete on 998 fully loaded 2up gained 9 MPG.
    Well worth it, just a little louder.
    washington state
    If you remove the cat do you need any programing?
    2012 Spyder RT SE5 Brake pedal mod
    Dec 2013
    Quote Originally Posted by jerpinoy View Post
    Nope, altho there is a possibility that idling it for 10 mins or so before riding off after the change will let the computer catch up with the difference. Not gonna argue about it, but I personally did the idle thing after fitting the cat eliminator with the stock muffler on my 2013 RT & have no issues, but I do now enjoy noticeably better mid range response & significantly better fuel economy... fully documented & witnessed by others!
    And everyone likes the change in the exhaust note!
