Results 1 to 20 of 20
    Feb 2017
    Central Ohio
    Default Help! Wind Buffeting
    In February I purchased a new 2015 F3-S.
    1. I installed the BRP windshield. The buffeting was so bad I did not have clear vision because of the wind rattling my head.
    2. I replaced the plastic shield with Gustafsson Plastic's 20" high X 30" wide shield. This helped tremendously but at highway speeds there is still considerable buffeting.
    If I raise my hand above the shield I have to go above my head before the force of the wind in considerable. If I go to the side, there is considerable force as soon as I clear my head. The buffeting wind is clearly coming from the sides. It affects my wife in the passenger seat as well. It is so uncomfortable I would sell the bike before settling with it. At this point I really don't want to ride it anymore.
    I have had bikes since 14 years old and have never had this issue. I don't want to keep throwing $$ at it as it adds up fast with Spyder parts. Any suggestions?
    What if you tried adding a Laminar Lip to the top of your windscreen?
    http://www.laminarlip.com/
    Feb 2009
    Ceresco, Michigan
    The MRA-xscreen will take care of your problem.
    I've previously used a Laminar lip which worked okay... but the xcreen is adjustable and works like a dream.
    I put an F4 28" on my Spyder F3 and really like it, but after you hit 65mph you need something more to keep from becoming a bobble head.
    They have a clamp-on kit you can get which is what I did, or you can drill and mount the brackets permanently to your shield. The actual screen part can easily pop on and off.
    http://www.twistedthrottle.com/mra-x...ield-extension
    Member wolffspyder's Avatar
    May 2016
    Deforest, WI
    I have. 25" F4 Customs on my F3 and I am 6'2". No buffeting because the windshield is wide as well as tall.
    Feb 2009
    Ceresco, Michigan
    Quote Originally Posted by wolffspyder View Post
    That's really strange as I'm only 5'8" and have the 28" F4 and get head buffeting over 65 mph. I suppose helmet aerodynamics can also play a role.
    Default Agree...
    another vote for the X-screen which is adjustable as well...As short as my windshield is on my RS when flipped up it makes a world of difference...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Bryant, Arkansas
    MeToo
    Cruzr Joe
    Invalid Emails
    Oct 2015
    morgantown west virginia
    I stopped in at my somewhat local spyder shop today and took a look at the new f-3 limited. all I can say is WOW! but to the point, it had a recurve windshield installed. I didn't know brp had such a thing. anywho, helmet dynamics can be a big source of buffeting also. case in point, I have been wearing a cheap Outlaw brand helmet (says U.S. NAVY on it),for over a year and always had buffeting issues at highway speeds. well today I wore my new Bell Pitboss helmet for about 4 hours and not once did I have issues with my head getting shook around. and I was rolling at 80 mph several times. food for thought.
    Active Member Air Wing Guy's Avatar
    Jan 2012
    Ohio
    Default HAVE YOU TRIED BAKER BUILT?
    I have attached two links of demonstration videos of what our Baker Built Hand Wings and Leg Wings do for the F3. These really help cut down the wind when closed and direct the wind onto you when its hot out. If you have any questions you can email us at info@bakerbuilt.com or give us a call at 1-800-451-9464 these should help you tremendously. Not to mention prices are affordable for this fix and have multi functions.
    Aug 2013
    Northern California
    Default Helmet
    Now that you mention it, I was wondering the same thing, could helmet aerodynamics play a role into this buffeting. I am only 5'8" and I have the stock shield on my F3L. I can hear the wind, but it doesn't move my head around, and even on a couple of 300 mile freeway runs it didn't bother my head. I wear a very high grade Arai full face helmet that seems to do a good job of moving the air around and through the helmet so that Buffetting is not a problem. Now my hands are a whole other thing, they get cold fast. So just asking, could the helmet style and or quality play a roles here?
    Jun 2010
    Las Vegas
    How about the Madstad? I've heard good things about them.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    If your helmet is too big for your head it will rattle your eye sockets even with minor wind buffeting. If your helmet is moving more than your head, it's too big. Extremely common situation.
    Mar 2015
    forrest above Reno, Nv
    Thumbs up Vented windshield
    I have vents on both my Spyder and Valkyrie windshields. No buffeting when the vents are open.
    Buffeting causes::::::::::::: Kaos
    2014 RTS , Circuit Yellow
    United States
    Quote Originally Posted by Blacklab1059 View Post
    I have BlueRidge Windshield and wear a full face helmet. You are still going to get some buffeting. Might want to read up in this thread. It addresses that issue.
    http://www.spyderlovers.com/forums/s...ith-turbulence
    If it's even a bit loose: your brain will act like a ball bearing in a soup can!
    Try adding a "Doo-Rag", as a short term solution...
    ...But getting a properly sized helmet should be the goal!
    Harrington, Australia
    Quote Originally Posted by Firefly View Post
    Wolffspyder doesn't say which model F3 he has, Firefly. If he has an F3-L, it's a different screen to yours, and the maximum height is the 25". The 25" stopped buffeting for me on my F3-L and I am 6'7". The top of the screen is about level with the bridge of my nose. I bought a Madstad at their maximum height, but it didn't work for me as it is not as wide across the top.
    Attached is a photo of the Madstad overlaid on the F4. The F4 is wider at the top, and has the cutouts at the bottom.
    HeliBars Handlebars
    Kenda Kanine rear.
    Oct 2013
    rome new york
    There is a lot of side wind' Have the same on my rs
    f4 windshield and side wings from baker will solve your problem
    Feb 2016
    HAWTHORNE nj
    Default AIR TURD
    HELLO, Lookup a product called sang its a windshield edging that has been around for quite some time and works great. I installed it on my shield .Its 11.00 dollars a ft .I own a rt and I have a stock height shield . I am 6ft 6inches tall and I can leave the shield in the down position and I don't get much buffeting at all..Try it and I am sure you will be pleased.
    Oct 2013
    rome new york
    Quote Originally Posted by MOSESS View Post
    got a picture
    Quote Originally Posted by bmccaffrey View Post
    got a picture
    It's actually Saeng......try this..
    https://www.saeng.com/product.php?id=581&category=80
    HeliBars Handlebars
    Kenda Kanine rear.
Tags for this Thread
