Starting problems on RT
I had been riding all week, turn off RT sat. night would not start next day. Checked the forum for ideas (thanks everyone). 1st thing I did was check battery hookup and put battery on charger. The batter did not seem to take a charge took it to a auto parts store, battery check out OK. Check all fuses and relays all good. Cleaned battery post. It is starting now. Well see what happen.
I see from your profile that you've got a 2016 RT...
(It's helpful if that information is listed in your "Signature line..."
Checking battery terminal tightness should always be the first step, and I hope that it has solved your difficulties.
If iut doesn't: let us know, and we'll help you dig deeper...
Good Luck!
Bummer...
Sometimes it is as simple as the kill switch, being in gear and not stepping on the brake or loose conections. Glad you have her going again but know you would like to know what it was. If....it happens again record you step in your mind to see what fixed it....
2012 RS sm5
PROPER CHARGING FROM DEALER
When I bought my Spyder ( new ) the dealer did not properly charge it ...... I have had issue with it from day one ........ just a thought .......... also put STAR washers on the terminals to keep them from getting loose ....... Mike
Battery terminals....
Just as a heads up for all new owners. I'm getting ready to install a 2 horn system on my 2016 RT-S. I took the battery cover off & found that the bolts holding the cables on the battery weren't very tight. Anyone getting a new spyder should check their battery connection. I was very surprised by the way they were.
AKA Jud Smales, Four Year Spyder Ryder!
"Quando Omni Flunkus, Moritati"
The Critter 2016 RT-S
Cat Bypass from Lamonster
BajaRon Sway Bar
Hella dual horns with relay
BRP Hitch with trailer module
Foam Grips
Adjustable Air Deflectors
Driver & Passenger Gel Pads in Seat
Shorty antenna
Ultraguard half cover
Gremlin bell from my son
Break Stripe Kit from Wrap My Spyder
First check to do...
Is your KILL SWITCH on ?
Silver RT Limited SE5 2013
BAJARON Anti-Sway Bar, BAJARON Heim Joints, SPYDERPOPS Bumpskid, SMOOTHSPYDER Belt Tensioner, SENA SM10 Dongle, CORBIN Passenger Armrest w. cupholder, UTOPIA Driver Backrest, SPYDERFLAP Mud Flap, STEBEL Nautilus Air Horn, TRICLED Rear Top LED Bar, TRICLED, 3rd & 4th Brake LED, TRICLED Mirror Turn Signal, TRICLED Tricfenderz LED Strip, CUSTOM DYNAMICS Front Mud Flap LED, CUSTOM DYNAMICS Amber Brightsides, CUSTOM DYNAMICS Red Brightsides, CUSTOM DYNAMICS Fender Tips ...
This is always a good thing to check... before you even begin to try and start the bike!
You'd be surprised at how many folks think that it's a cute joke to play on a biker: hit the kill-switch, and let them figure out what happened!
When I took the PA motorcycle safety class they told us to get used to using the kill switch any time you are shutting down the bike. That way it becomes automatic in an emergency situation.
BajaRon Sway Bar
Foam Grips
Shorty antenna
Interesting, last thing I would consider is killing the engine in an emergency unlessit was on fire.
Once the engine is shut down, you have no way out to move if needed.
I am not sure, but engine off may shutdown power steering also.
The owners manual does mention to learn the effects of shutting down the engine while moving.
I agree that checking the kill switch should be the first thing to check if it doesn't start. For some reason on my Spyder I find that occasionally I accidentally hit the kill switch; I suppose when mounting or dismounting. Now with respect to someone playing a joke by hitting the kill switch: are you kidding??? Where I come from you don't touch another persons bike ever; unless invited to do so! If I were to play that joke I would expect to get my butt kicked!!! We are very friendly people out west but we don't screw with another persons ride.
