Results 1 to 20 of 20
    Mar 2016
    US
    Default Found this in my drive belt
    I was pulling my Tupper ware and found this on my drive belt. Sure looks like it's coming out of the belt. Not something that penetrated from outside. Has any one had something like this happen? I have a 2016 RTS with around 2000 miles.
    Sent from my SM-T800 using Tapatalk
    Bossier LoUiSiAna
    Have not had but looks more like something being pushed thru from the inside Been on any gravel lately?? If you can inspect sprockets too make sure it's not a bur or damaging them too
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Thinks out loud Jeriatric's Avatar
    Apr 2012
    "The Skillet" AKA..... La Quinta, Ca
    Default Oops
    Are you saying there is not an entry point from the sprocket side of the belt?
    Default EHAT OBJECT
    Please position your belt so you can twist it ( you might have to put a wrench on it for leverage ) and look on the inside ......take a pic before you remove whatever it is ..... then take pics of the object ......... slowly rotate your sprocket and examine between ALL the teeth to see if their is any Serious damage to the Sprocket ..... to me the object looks like it could be glass ....... Mike
    Mar 2016
    US
    Bluek night you are on to something, it does seem to be a through and through. I will inspect the sprockets and removed the object tomorrow, looks like I'll looking at replacement of the belt, thanks.
    Mar 2016
    US
    Not sure how to add the picture to this
    Mar 2016
    US
    Figured it out
    Default MYSTERY OBJECT ?????
    Thanks for the pic , however I can't tell what it is yet ???? ........ Let us know after you get it out ...... and the belt might not be NEED to be re-placed immediately ........ I would definitely get one, but maybe not put it on yet...... A damaged CHAIN is a much worse situation than what you have ........ jmho ..... Mike
    Jul 2010
    Las Vegas, NV
    Default Agree
    Mark the damage with a silver sharpie pen. Keep using it. If the damage grows, replace it. If not, use the one you have. I used one like that 40,000 miles!
    Joe Meyer
    Very Active Member Deer Slayer's Avatar
    Mar 2015
    Advance, NC
    Tar and rock road. I had a small stone stuck on my rear sprocket with tar. If i had not found it, I suspect I may have seen the same thing. Check your ryde after a fresh tar and rock road.
    If I can't fix it, I will fix it so no one can fix it. Sypder Loco!
    May 2013
    Stanton, ca
    Here is would I would do and I saw it done before.
    Pry out the rock or whatever.
    Go get some black rubber sealer.
    Put it in the hole and press down on the rubber as best you can making sure the sealer does it's job to basically glue the rubber back.
    On the inside clean up any excess rubber sealer.
    The idea is it might keep the damage from expanding with use.
    I met a guy that did this and he is still using the belt and it's been at least 2 years now.
    I would buy a extra belt just in case.
    Bob
    2011 RT-S SM5 - Black
    Sep 2016
    US. ohio n/e
    Quote Originally Posted by jcmcalpinjr View Post
    Ive had that on my hd...it was a rock pushed threw...i ask around back then ...they said it really no problem...as long its not on the edge...that was true...rode it 30k more miles till i traded in
    Sent from my LGLS675 using Tapatalk
    Quote Originally Posted by cptjam View Post
    It's a good thing that you found it!
    Very Active Member KX5062's Avatar
    Aug 2012
    Central Coast, CA
    Yep, you picked up a rock between the pulley and the belt. I agree with Joe, keep a very close eye on it. Keep the photo you posted and compare it side by side between the photo and the real thing to verify that it's not growing.
    2020 RTL SE6
    Jul 2011
    Mitchell, Ontario, Canada
    If it was mine I would just drive on and not really worry about it. But you are not me. If you think it is going to bother you and reduce the enjoyment of driving your Spyder in any way. Put on a new one.
    2018 F3 LIMITED
    Mar 2012
    NJ
    Agreed! 👍
    Sent from my Nexus 6 using Tapatalk
    Mar 2015
    Advance, NC
    Quote Originally Posted by KX5062 View Post
    I agree, run that sucker!
    Jun 2014
    Gettysburg, PA
    Default Only YOU....
    know if this is going to bother you as you ride. There is no reason to replace the belt except for your peace of mind. I would not worry about the stone either. At some point, may have noticed a moderately loud noise and the bike shook as if you hit a rock with the rear tire. THAT was the moment the rear sprocket forced the stone through the belt. It's happened to me twice now thanks to my local town guys "cindering" my personal driveway every winter when it snows. They usually get back to sweep up the cinders about 2 months after I start riding my Spyder after it's winter hibernation. Those little stones are also responsible for taking out my adjustable air bag and compressor system. My town has not cost me upwards of $1000 but, I keep sending them hard earned (tax) money 'cause it'd be hard to ride my Spyder from jail!
    NEVER, look straight up at a bird ....NEVER drink downstream from the herd ....and NEVER, EVER squat....with your spurs on!!!
    Default Agree...
    Another one for watch and keep ryding. But if your not comfortable change it and keep it for a Backup... do check both sprockets
    ​2012 RS sm5
    Active Member Buckeye Chuck 54's Avatar
    Jun 2015
    Zanesville Ohio
    Default Rock in belt.
    I noticed the same thing in my belt at 9,000 miles. The dealer told me to replace it but I thought I'd just keep watching it to see if it got worse. It didn't and I now have over 100,000 and still going!
    Chuck
