I just got off the phone with my dealer, he is going to call brp and said it may take 2 days for him to hear back. Sounds like it will be a painless operation.
Originally Posted by oldwarriorrider
Congratulations, this isn't good to hear after all of the BRP bashing that we hear, thanks for posting it, especially when you consider that this is a three or four year old model!
Joe
Will can am fo that for a 2012 also!! Mine is an RT
We had Can Am put the 2013 recall scoops on our 2012 under this act of good will. My wife told them the heat at the front of the seat was unbearable.
2016 F3 Limited
2019 Ryker Rally
2014 Suzuki V Strom 650
2020 CSC TT 250
You are talking about two different things. The ST and RT panels are not the same, but BRP has replaced both in the past. Read the past posts and you will learn all about it.
Good Luck,
Roger
2014 ST-L
Originally Posted by Explorer
You are talking about two different things. The ST and RT panels are not the same. Read the past posts.
Good Luck,
Roger
Never said they were the same but I had the 2013 recall scoops put on my 2012RT for free.
2016 F3 Limited
2019 Ryker Rally
2020 CSC TT 250
Joe
I missed the call from my dealer, which is Caswell Cycle in Mora, MN. Thankfully he called me back letting me know my new side panels are in and we set an appt for next week to have them installed while I wait. Can't say enough good things about Les and his crew at Caswell Cycle!
Done
I just got mine completed the other day. The dealership that I bought mine from (pre-owned 2013) contacted Can Am for me and got everything approved at no cost to me. Not only does it look better but I can actually feel the heat coming out of the vents in the new panels. I'm so glad I learned about the fix on this forum. All that heat used to be trapped inside!
New panels installed on wed, they look awewsome but unfortunately with all the rain we have had I haven't ridden it yet. Can't wait to check the temp gauge and see if it makes a difference.
