Quiz time....
I go to my dealer to get my rear tire changed out. I get my byke home and I hear a sound - a rubbing sound as I roll into the garage. It is periodic which means I hear it, then the wheel rolls little further and then I don't hear it until the wheel does a full Revolution and then I hear it again.
What did they do wrong?
First correct answer gets my full respect and admiration!
hmmmmmmmmmmmm
maybe a 'bubble' in the side-wall of the tire....
Dan P
SPYD3R
Drive belt tight against back sprocket? Belt guard?
forgot to remove tire tape?
David
They left the sticker on the tread.
AKA Jud Smales, Four Year Spyder Ryder!
"Quando Omni Flunkus, Moritati"
The Critter 2016 RT-S
Cat Bypass from Lamonster
BajaRon Sway Bar
Hella dual horns with relay
BRP Hitch with trailer module
Foam Grips
Adjustable Air Deflectors
Driver & Passenger Gel Pads in Seat
Shorty antenna
Ultraguard half cover
Gremlin bell from my son
Break Stripe Kit from Wrap My Spyder
Thinks out loud
i'll bite
Brake pad contacting the rotor? WAG
Forgot to torque rear axle so sprocket is not seated and wobbles
Now 2014 RT Limited Cognac
Was 2008 GS SM5
Don Garbarino
Cup Holder
GPS locking holder
Mud flap
Modified KNOTT grill
Phone holder and charger
Trailer hitch
Dual air horn
Auxiliary fuse box with relays
Heated clothing controller
volt/oil pressure gauge
Sequential signals in mirror
Tri Axis Handle bars
Baja Ron anti sway bar/heim links
shorty antenna
And many more
it has to be !
it has too be the " comes and goes " nut adaptor that is very close too the " almost never hear it bearings " going to have too lift the rear end up off the ground , and roll the tire in neutral , and see the alignment of the tire it must be real close but enough too rub , in one spot ...
Well,could it be
Possibly dropped a weight inside the tire?
So who had the right answer?
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
I'm not sure what the right answer is yet. Tomorrow I'm going to jack it up and take a closer look and I wanted to get some good ideas before I dug into it.
Ozzie Ozzie Ozzie
