Results 1 to 15 of 15
Thread: Kuhmo AST Tire
    Active Member michrick's Avatar
    May 2015
    Liverpool, NY
    Default Kuhmo AST Tire
    Is this tire also known as the Kuhmo AST KU25? Getting ready to put a new sneaker on the wife's ST and the OEM wore out at 5500 Thanks
    2016 RT Limited , White
    Active Member Richardv's Avatar
    Oct 2014
    Montreal north shore, QC
    Default Yes....
    Quote Originally Posted by michrick View Post
    ...it is see this link: https://www.tirerack.com/tires/tires...odel=Ecsta+AST
    Richard
    * 2012 RS SE5 (hers)
    * 2013 ST SM5 (mine)
    Daughter RSS SE5 2014
    Son in law RSS SM5 2013
    P.S. 3 Kumho AST 225/50R15 and 1 Toyo Proxies 4 225/50R15 rear tires
    2 sets of Kumho 175/55R15 front tires
    1 set of Hankook V4
    1 set of Canadian Tire General tire Evertrek RTX in 14" for the 2012 ...
    May 2015
    Liverpool, NY
    May 2015
    Liverpool, NY
    Any truth that a dealer won't mount anything other than the Kenda?
    Apr 2011
    GREENVILLE, SC
    Default HALF n HALF
    HALF-n-HALF....
    ask your dealer... if they won't, look elsewhere... i've had NO problems, and i've mounted 9 non-OEM tires on my various SPYD3Rs....
    Dan P
    SPYD3R
    May 2015
    Liverpool, NY
    I found one they just want a waiver signed because it's not OEM but the mounting, balancing and install they will stand behind, not the tire. So I've ordered a Kuhmo tire. Thanks
    Mar 2015
    Brockport, NY
    Default Maddies motorsports
    Head over to Maddies in Dansville, there only 25 minutes from you. They should take care of you. If not, I had the Kuhmo installed by Filers Powersports in macedon up towards me. I'd be glad to help with transport if needed!
    Brent
    2014 RT-S Pearl White
    May 2015
    Liverpool, NY
    Hey Brentec we talked year I had a white Victory Cross Foundry Tour and my wife has a 2014 Cam Am ST I sold my Victory and bought a 2016 RT Limited from Filers in Macedon. And they will put a Kuhmo on the RT. I'm not to upon Maddies even after buying nothing my Victory and St from them, long story. If your down this way over the summer we need yomeet up
    Mar 2015
    Brockport, NY
    Default Definitely
    Sounds good, love riding through your area. We will have to connect this summer and take a spin.
    Active Member kamper's Avatar
    Apr 2016
    Elkton South Dakota
    M kumho came ups yesturday. now waiting for it to warm up on my day off to take to the shop for mounting. They are charging 100 to do the complete job. Not sure if that is out of line but I'm going to give him a chance and see how he does on a simple thing just in case I need him for big stuff.
    May 2015
    Liverpool, NY
    Sounds about right that's what I'm being charged here in NY
    Mar 2015
    Brockport, NY
    Default Almost forgot
    Make sure you mention to the tech at filers about putting the valve stem back in same position it came off. Mine was spun 180 degrees from correct position and now valve is even more difficult to get to when trying to add or adjust air pressure.
    May 2015
    Liverpool, NY
    Will do Thanks
    Oct 2014
    Default You might also want to know....
    Will do Thanks
    .....that your dealer will most probably inflate the Kumho to 28 - 32 lbs. This is way to much for your tire on a Spyders. A car tire is way stronger than a Kenda "bicycle" tire... (check your bicycle, kenda is the tube/tire supplier to 95% of thoses tires)....start with a pressure of 20 - 22lbs it will be more than enough....
    Richard
    Richard
    1 set of Hankook V4
    May 2015
    Liverpool, NY
