Thinking about TricLED lights
...but there are no installation instructions that I can find on their website. I don't want to take on more that I can handle, and even if people say "It's easy, you'll do fine", I want to read it for myself before I guy to see what is involved. Any ideas?
Thanks
TricLEDs offers some of the most complete, and easy to understand instructions...
As well as the BEST LED lights for your Spyder!
What is that that you want to add to your bike? Perhaps someone in here can email you a .pdf file of the instructions...
FOR THE RECORD: I also like to get the instructions a bit early, so that I can plan things out...
Im looking at the RT stop and tail light package.
Tricled
Value axceriores .com has video on head light ang fog lights a many other led install visions and they try it before the sell it
Thanks
I just installed these on my 2012 RT..If you pm me your email,I will scan them and email the instructions to you...Basically,remove Tupperware,unplug harness and the harness they supply to you plugs in series...
Thanks
The easiest install and I think best Rear LED's for the money to start with is the RT Rear LED Saddlebag Run/Brake/Turn from TricLED.
I am going to make an install video, just been busy and have not gotten around to it.
If you can take your rear trim off and then remove 3 bolts to pull out your tail light you can do this. It is all plug and play.
Is it just the 3rd and 4th brakelights?
Or is there more to it?
(I'm unfamiliar with their packages... )
I have all of the mechanical aptitude of a hamster, yet I was able to install these, (and many, many more!), on my RT Limited.
In fact I just ordered the running lights/Brakelights that fit into the rear of the saddlebags!
yeah, that's the one. Thanks! I'll take a look.
Thanks
If you contact Reggy at TricLED, I'm sure he'd email you a set of instructions to see what you're getting yourself into.
Bob, I have the running/turning/brake lights on the rear of the RT that fit into the rear of the saddlebags, and under the trunk lid, , and between the brake lights.
Here are some pictures of the LED'S that I have: Rear LED lights+ turning signals 003.jpg these are on the right side/ turn/running/brake.
Here is a picture of the same lights on the left side: Rear LED lights+ turning signals 004.jpg These are on the left side/turn/running/brake. Also, they are bright, and they fit into the rear of the saddlebags.
I bought them from Spyderpops. Deanna
Gremlin Bell
SpyderPops Missing Guard Belt
Ultimate F3 Floorboards
Sway Bar with Links
Rolo Laser Alignment
Half Cover
Show chrome Trunk Shock
Gremlin Bell
Sway Bar with Links
Half Cover
To install TricLED's 3rd and 4th brake light, you need to remove the part of the tupperware that covers the rear trunk. Instructions included with the lights is good. I'll add to Mr Denman's advice with one WORD OF CAUTION..maybe two.. when you remove that tupperware part, remember to tilt it a bit back and then lift STRAIGHT UP. Remember there are four tabs that extend into the black plastic. These four screws are what holds the tupperware in place. Do NOT break one of those tabs. It would be best if you had a helper to remove the plastic, someone to help lift and as it is lifted, press in lightly on the tabs so the metal clears the slot. Also remember to note that there are three tabs that need to be put back in the same place. Kinda easy to not do that. Again, ah helper would be good. Two tabs at the bottom that go over the upper lip of the black plastic and one that fits into a slot just below the trunk lock. If your trunk won't close, that's the reason. If you DO manage to break one of the tabs, not a disaster. There is a product, "Q Bond" (most likely found at an auto paint supply store), that will repair gray plastic and make it stronger than original. You only have 10 seconds to work as it is cyanacrilate OK crazy glue, hence the need for a third hand to hold the broken piece exactly in place. Build up powder layers around the break for strength. If you break a tab, you'll need three hands to repair it. But it's easy. Be careful where you position the wires that go behind the tupperware. And how you replace it. It is a bit fragile. Experience is a great teacher. Thanks for Reggie's support.
Thanks everyone for the help. Now, just because I can't go home with the first pretty face in the joint, has anyone tried the Spyderpops Brake/Run/Turn with Strobe? It seems like it may provide more bang for the buck for my needs.
http://spyderpops.com/rt-brt-rear-li...g-n-play-easy/
I have the Spyderpops Rt-brt-rear- lighting kit - 4 sections brake/run/turning ( SPY184) on my 2014RTS-SE6. Here are some pictures:Rear LED lights+ turning signals 004.jpg left side turning Rear LED lights+ turning signals 003.jpg right side turning Rear LED lights+ turning signals 001.jpg under trunk lip/below trunk lock. These are bright They come with easy instructions to install. I have a 2014RTS-SE6 Deanna
Gremlin Bell
Sway Bar with Links
Half Cover
The Spyderpops Brake/Run/Turn/Flash set is what i have on my F3 Limited and i love them, i also had them on my RTs and they looked good and were very dependable and less expensive than most other vendors, plus the support goes on way past the sale. I highly recommend SPYDERPOPS for LED lighting, the prices are better and the service is great.
When you get the Spyderpops set, it is complete.
Cruzr Joe
Timely thread
Printing out Bob's and Ric's instructions on panel removal as I type.
Thanks.
I have run brake turn set from spyderpops very good instructions , tricleds instruction were not as thorough as spyderpops
I,m thinking of adding the extra brake and tail lights that are plug and play.Since i plan on buying a trailer in the future will the wiring thats plug and play for the trailer wiring all plug together?Since it,s apart i would like to do it all at the same time.
Bill
There's eight of them...
Four up around the edge of the top trunk.
(Two in the center only hold the latch in place: leave them alone...)
And two more hidden down in the top rear corners of the saddlebags.
Thanks Bob,
My bad - I typed 6 instead of 8 (post edited)
The center two -- I already figured to leave alone but only after I'd loosened them
Looks like it's going to require more force and finagling than I've been willing to apply.
I'll give it another try this weekend. I'll keep you updated with the positive result.
