Results 1 to 4 of 4
    Feb 2009
    Upstate, NY
    Default Replace Clutch Lever Question
    Ok...trying to remove th stock lever to replace with an ExtremeKempy lever:
    1. I removed the circlip,
    2. Hit the bottom of the lever pin mildly to see if it would/had moved - no cigars,
    3. The pin looks like it may be threaded????
    Any advice?
    Thanks....Karl
    PhotoShop Master
    Jun 2008
    methuen ma/salem nh
    just did mine last week the top of pin has grooves in it put your hand on top of lever and tap pin on bottom with hammer dont forget once pin is almost out hold clutch piston in with finger then put new lever in place ....cal if needed 603-401-2760
    Feb 2009
    Upstate, NY
    How hard did you have to hit the pin from below?
    You say to hold in the clutch piston as I remove the pin/lever...any other 'gotchas' I need to know about?
    Feb 2009
    Upstate, NY
    Thanks to tatt2r for the quick reply and assistance! Got 'er done.
