Page 2 of 5 FirstFirst 12345 LastLast
Results 26 to 50 of 104
  1. #26
    Sep 2012
    Junction City, KS, USA
    PrairieSpyder (Patti)
  2. #27
    Mar 2017
    Minnesota
    Thanks for the comments you have my my decision to buy the RTS a little easier. I loved my big touring bikes but dreaded the hassle of turning them around or hitting the occasional dirt road or parking lot. Getting use to the handling will be easy because of my Can Am Outlander 800 with power steering. I really love the 41gal of storage space on the RTS and now have to get down to dealer and take one for a ride.
  3. #28
    Very Active Member HayRog's Avatar
    May 2013
    Sacrament0, CA
    Before we decided to buy the RT-L we rented one for a day from the dealership. Rode about a hundred miles or so and confirmed our decision.
    The dealer deducted the rental price from the cost of the bike
    We also bought a "leftover" 2015 model cause the 2016's were arriving. That saved us $4,000.00.
    Great deal all around
    Or as my friend Ray says -- "we bought a $24,000 GPS and got a free Spyder with it"
  4. #29
    Active Member ricford's Avatar
    Jun 2015
    Calhoun, La
    STOP LOOKING....!! Test ryde them and go for it...You can go for the base model and with all the cool products out there now and the money you save you can build exactly what your looking for.
    I agree FULLY with Chupaca and add my vote to buying the basic RT. If you get the super duper delux model with all the stuff they offer, it's STILL not enough. You're going to want to improve the handling which means changing that not very good factory anti-sway bar with a Bajaron bar, you'll want to replace all three shocks with Elka + shocks, you'll want to replace the tires with decent quality performance tires, ....well, there are very many after market products that improve the performance of the bike. And they're needed if you ride more that on Sunday for a couple of hours. If you tour, you'll definitely NEED to do these multiple things to make your bike perform better, be safer and more comfortable. This means that if you buy the RTS at say $32K (I think that's about right, not sure) and then spend another $6 K upgrading the bike to where it should be... Or buy the RT, do nothing and not ride very much. Or fast around any curves. But, that's me. I've managed to upgrade my RT to the tune of about $6K and not one farkle. All performance stuff. I ride hard. Don't speed, just don't putter down the road only on sunny Sunday afternoons. And what I've gathered from reading many posts, some folks manage a dozen Iron Butt rides a month. Or so. This Spring I have n 8K mile trip planned. Just waiting for the cold to simmer down up North.
  5. #30
    Registered Users Mr. Pickels's Avatar
    Feb 2017
    North West Arkansas
    Default AHHHH
    Quote Originally Posted by larryd View Post
    If your going to be riding with a passenger you may want to think about the RTS because of the adjustable air ride feature...larryd
    Very good Point!
  6. #31
    Default WELLLLLLL NOW THAT YOU MENTION IT
    ALL - RT's have adjustable air ride ........ for those who are extremely lazy the " S " and " LTD " model's are automatic .............. Mike
  7. #32
    Active Member DC1's Avatar
    Feb 2015
    McLain, MS..
    Default Pressures....
    Quote Originally Posted by Spin View Post
    Switching from 1 to 2 up won't be an issue so I'll probably stay with the RT. What pressures do you use for 1 or 2 up?
    I kinda worked it bass ackwards...
    260 lbs 1-up = 40 psi
    520 lbs 2-up = 65 psi
    Since the dealer had the headlights so out of whack to start with that the high beams were like low beams.....
    1, I found the perfect 2-up pressure for us....
    2, Then popped the side covers off and adjusted headlights accordingly....Just a turn of a knob on each side and easy to line up using low beam...
    3, Then experimented with how much to drop the pressure for 1up....
    We are big folks, lighter folks will need less pressure....Just experiment with it till you get the ride you like..(not sitting too high in the rear but not bottoming out on bumps either) and if needed the headlights can be adjusted to match easy....
    Not sure if that was the right way, but it's what I did! LOL!
  8. #33
    I have only had two base models--a 2008 GS SM5 and a 2009 SE5.
    I then went to RT's. Had a 2010 RTS Premier--which was pretty much loaded with everything. Also a 2011 A & C which had cruise control and radio. No adjusting shocks on that one. The 2014 is a RT-S with radio, cruise, and the push button adjustable shocks.
    They are all good--depending on the level of amenities you want. A test drive is advised.
    Member SpyderDriver's Avatar
    Mar 2017
    Monroe, GA
    Default Go for it!
    Today I finally bit the bullet and bought a barely used 2015 RT Ltd. I shopped around a lot and got a great deal! I hope you find yours soon!
  10. #35
    Vermont
    My first spyder was a 2012RTS-SE5, I did not put on any farkles, had my first spyder for 1year 1/2, then took a demo ride on a 2014RTS-SE6 in Springfield, MO( during Spyderfest) WOW what a difference, like night/day.
    So when I got back home( Vermont) I bought a brand new 2014RTS-SE6 Cognac. So, I am not turning back, I have added a lot of farkles, (look @ my Albums to see the farkles that I have done ) The 2014RTS-SE6 is my current , and I have 16,000 miles on it. I have added LED'S,( on fenders, side markers, trunk, below trunk lock, decals, spyder pockets, painted dashboard( mike-blueknight911 painted), short antenna, etc. Here is a picture of my spyder: Spyder Farkles update 001.jpg newest farkles on RTS-SE6 COGNAC 008.jpg dashboard on spyder14RT 004.jpg LED'S lights on a 2014RTS-SE6 010.jpg The LED'S, DECAL'S I bought from the venders on this site( TRIC-LED, WRAPMYSPDYER.COM, SPYDERPOPS).
    I love my 2014RTS-SE6.
    Deanna
    Last edited by Deanna777; 03-06-2017 at 11:53 AM. Reason: Added to post @ 10:02 pm 3/5/17
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
  11. #36
    Active Member LateLifeCrisis's Avatar
    Maryland
    Default HAHAHAHAHA
    Quote Originally Posted by HayRog View Post
    "Or as my friend Ray says -- "we bought a $24,000 GPS and got a free Spyder with it"
    He's on his RT She's on her F3
    And the Keys to a Happy Marriage: Separate
    Bathrooms, Individual Remote TV Clickers, and
    His and Her Spyders.
    "If there are no dogs in heaven, then when I die,
    I want to go where they went." ~ ~ Will Rogers
    "Never in the field of human conflict was so much owed by so many to so few."
    ~ ~ Winston Churchill in his tribute to the RAF.
    "I'd like to know why well-educated idiots keep apologizing for lazy and complaining
    people who think the world owes them a living." ~ ~ John Wayne
    GOS 3799
  12. #37
    Quote Originally Posted by jjones0828 View Post
  13. #38
    Member DSSpyder's Avatar
    Feb 2015
    Waynesville, OH
    Go for the RT S, the upgrades are worth the price. I love my 2014 RTS
  14. #39
    May 2014
    Benson, NY
    I run 40 lb in mine 1 and 2 up. We total about 350 lb. I started out with 50 lb but experimented and settled on 40.
    2015 RTS Special Series
    Russell Day Long seat
    F4 Customs windshield
    Sena 20s
  15. #40
    Vermont
    Quote Originally Posted by DSSpyder View Post
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  16. #41
    The advantage of the ACS is because it will maintain a constant ride-height, by automatically adding or reducing the air pressure.
    Once you get your headlights set to how you like them: adding a passenger won't have you looking "up into the treetops", and riding solo won't have you "looking for night-crawlers".
  17. #42
    Mar 2016
    Astoria, Oregon
    ALL - RT's have adjustable air ride ........ for those who are extremely lazy the " S " and " LTD " model's are automatic. Mike [emoji106]
    What? This is true?
    Sent from my SAMSUNG-SM-G890A using Tapatalk
  18. #43
    Mar 2017
    Long Island
    Looks like my local dealer will match a price I found on the internet on a RT, plus what it would cost me to ship. Fingers crossed!!
  19. #44
  20. #45
    May 2013
    Apex, N.C.
    That is great. I wish our local dealers here in middle NC were that nice. I offered 3 of my local dealers the price I found in Texas, plus $1000. All 3 flaked out on me. I ended up purchasing from Texas and having it shipped here for +-$800. Nice smooth transaction.
  21. #46
    Feb 2012
    Spring City,Utah
    Quote Originally Posted by LateLifeCrisis View Post
    Yeah I bought a $6000.00 Harmonica once and got a free Jeep Grand Cherokee
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
  22. #47
    Feb 2017
    North West Arkansas
    Default Go for it.....!
    My wife and I are looking at a new RT. I am new to Spyders but I have ridden bikes for years and also have a Rennegade 800. Any comments or advice would be greatly appreciated. Thanks!!
    tonyspin is online now Report Post
    Don't think.... "DO" it... I am right behind you buying in 9 days..
  23. #48
    Nov 2015
    Myerstown, Pennsylvania
    Default Do's and Do not's.....
    I don't know if anyone said anything about this but I found a lot of valuable info here:
    http://www.spyderlovers.com/forums/s...-Spyder-owners
    I think this stuff is a must read for new and prospective buyers.
    The Critter 2016 RT-S
    Cat Bypass from Lamonster
    BajaRon Sway Bar
    Hella dual horns with relay
    BRP Hitch with trailer module
    Foam Grips
    Adjustable Air Deflectors
    Shorty antenna
    Ultraguard half cover
    Gremlin bell from my son
  24. #49
    Feb 2017
    North West Arkansas
    Default Bravo
    Quote Originally Posted by SteveLaoyster View Post
    That post was very helpful when I was first looking at the Spyder.
  25. #50
    Mar 2017
    Long Island
    Really great info here!! We decided we are going to get one!
    Still working out the numbers with the dealer, though. He suggested a warranty, 5 years for $1500. I guess it really is 3 years on top of the 2 you get with a new machine. What do you guys think about that?
