Page 3 of 3 FirstFirst 123
Results 51 to 70 of 70
  1. #51
    I might be wrong... but didn't their 2010 setup originally include back-up lights?
    It might have. There is no user manual for the 2010 trailer on the BRP website. The earliest is for the 2011 trailer and it shows the trailer as being only a 4 wire system, hence combined turn/stop lights and no backup lights.
  2. #52
    The operative part of that quote is, "should probably have".
  3. #53
    Active Member michrick's Avatar
    May 2015
    Liverpool, NY
    Ok this may sound stupid but who is Pierre? Secondly I used to pull a trailer behind my Victory it was a 5 flat, I've just retired it back to 4 flat I hope my new 2016 RT Limited will work properly with the BRP wiring set up. If not I will have to try something different.
    2016 RT Limited , White
  4. #54
    Quote Originally Posted by michrick View Post
    You shouldn't have any issues with the trailer connected to the RT. You'll need to get or make a 4 square to 4 flat adapter. The easiest way is to cut the 4 flat in two and tape one half above the other and plug it in!
    Pierre is SpyderTV. I don't remember what his accessories business name is and I can't find a link right off the bat. He's in Canada.
  5. #55
    May 2015
    Liverpool, NY
    Thanks much
  6. #56
    Oct 2011
    Kalamazoo, Mi
    Default trailer hitch OEM or aftermarket
    However with a computer controlled cycle you must have electrical isolation to prevent arching into the computer.
    I'm confused; where is all the electrical arching coming from with a trailer?????
    Al
    2018 F3-T
    2018 F3-T , Pearl White
  7. #57
    Quote Originally Posted by IGETAROUND View Post
    Al
    You probably already know this but I read this as a case of the words not conveying the intended meaning. I think he's referring to surges. Apparently the earlier Can Am isolators were sensitive to surges in the ground circuit of the trailer lights if the ground path, or part of it, was made through the tongue and hitch ball contact.
    I don't know how vulnerable systems are on other bikes like the Goldwing, but I maintain we need to be careful with the Spyder. The turn signal power comes directly from the cluster with no fuse or other protection in the circuit. If you connect trailer light wiring directly to the bike turn signal wiring you create the possibility of mucking up the cluster. If the turn signal wires on the trailer short out you could, maybe, damage the cluster. That would be a multi hundred dollar repair. You also could strand yourself in the middle of the dessert, or city, or wherever if your cluster goes south. An isolator only pulls enough current from the turn signal wires to activate a relay which sends power from the battery to the trailer lights. If you have a disaster with the trailer wiring the isolator prevents damaging the bike circuits. As for brake and tail lights a short in the trailer won't kill the fuse protecting your bike lights if you have an isolator in the circuit.
    The isolator is insurance against unknown failure modes and restricts trailer electrical disasters to the trailer.
  8. #58
    Very Active Member Deer Slayer's Avatar
    Mar 2015
    Advance, NC
    Al
    I will try one more time. If the wiring on the trailer should be come frayed and arc to ground, this is called electrical noise. This is what shorts out components in the converter on a Spyder. The idea is to open the circuit fuse and not take out the the circuit. The isolator I use is powered directly from the battery with a master fuse, and each trailer wire has a fuse. THIS IS TOTAL ISOLATION! This is about the best I can do for those of you that do not have an electronic background or just trying to up your thread count.
    If I can't fix it, I will fix it so no one can fix it. Sypder Loco!
  9. #59
    Mar 2015
    Advance, NC
    Thank you, Bill...
  10. #60
    May 2015
    Liverpool, NY
    I would hope the BRP product would avoid that happening my Yamaha Venture and Victory Cross Country used the happy isolator, no issues plulling the same trailer. If the BRP product dosent prevent any back feed what reason would we use it? I just purchased a 2016 leftover RT Limited and I'm waiting on the BRP hitch and plug and play electrical to come in now I'm on the fence as to what to do
  11. #61
    May 2015
    Liverpool, NY
    Last thing I want to do is burn up the Peter, sounds to me that BRP is trying you make you buy a RT622 or a Freedom trailer?
  12. #62
    Jul 2011
    Mitchell, Ontario, Canada
    BRP uses the Hoppy Circuit Guardian isolator.
  13. #63
    May 2015
    Liverpool, NY
    Great so I should be all set
  14. #64
    Oct 2011
    Kalamazoo, Mi
    Default knock off or BRP hitch
    OK, if this is the case when you look at the information on that isolator it says that it's re settable and multiple use for more than one instance of a short occurring.
    Now having said this, why are there multiple instances of individuals on this forum replacing their isolators multiple times??? I'm easily confused about things electric.
    Al
    2018 F3-T
  15. #65
    Jul 2011
    Al
    It has an automatic self reset function. A short in the trailer is not going to cause any harm to the unit. The fuse will blow protecting it. Fix the short and replace the fuse no harm done.
    In the cases that people have complained that they have burnt out their isolator and it has been blamed on the trailer wiring. The fuse is still intact. The problem is not a short. The problem is a bad intermittent connection. It does not matter if it is a BRP trailer or aftermarket. It can happen on the ground or the power side of the circuit. The electronics in the isolator cannot stand up to being turned on and off hundreds of times per second as the trailer bounces down the road. You have probably followed a trailer down the road with its' lights flickering. That's what kills the isolator module.
  16. #66
    Feb 2012
    Spring City,Utah
    His accessory outlet is www.canamspyderaccessories.com.
    Pierre is SpyderTV.net and Can Am Spyder Accessories. They are in Canada but he comes down here to many of the Spyder events. He was at Red Rocks last year and I think he is coming back again this year.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
  17. #67
    May 2016
    Okotoks,Alberta, Canada
    Default Wiring harness 2015 freedom trailer
    Hitch and control module on its way from BRP ... Hitch will be no problem .. Little worried about the wiring .. Going to attempt myself .. And videos ? Installation manuals out there ? I have a 2015 RTS trailer is a 2015 Freedom trailer
    Send links !!!
  18. #68
    May 2016
    Default Intructions ... not so good
    Quote Originally Posted by Blackie312001 View Post
    Send links !!!
    Hitch n module just arrived .. whoa instructions look horrible !!
  19. #69
    May 2016
    Default BRP trailer hitch n control module
    Installed my hitch n control module on my 2015 RTS
    Not difficult at all ... 2.5 hrs and I had never removed Tupperware before .
    Whew !! Lol
  20. #70
    Active Member BlueKnight's Avatar
    Feb 2011
    Hamburg, New York
    Default Hitch
    I bought an aftermarket hitch off eBay for my 2011 RT Limited, bolted on exactly like the OEM hitch and was removable like the OEM hitch, cost half the price. Also bought an aftermarket tail light converter and wired it to OEM connectors from Tricled so it was all plug and play NO splicing (hate cutting into the harness). Wired it to a standard 4 pin to hook up to a Harbor Freight Tag Along Trailer and no problems, I did have to change the lights on the trailer to LED's.
