trailer hitch
am picking up a SE5 in a couple weeks...need to put a hitch on. Saw one on ebay. it's attached thru the rear wheel.
Wondering if this will cause problems with the tire or wheel bearings?
I have a wheel chair carrier to bolt on the carrier (missing a leg) total weight on ther tongue under 70 lbs.
You have a unique situation with mounting a wheelchair. You might want to do some searching on this site for others that have mounted wheelchairs.
I personally would never use a hitch like the one in the photo that mounts directly to the swingarm. Bushtec makes a Spyder hitch - and they did it the correct way.
http://www.bushtec.com/spiderhitch.html
Little more expensive than the 'Ebay' one, but as with anything - you get what you pay for. You shouldn't need the harness kit if you're not actually towing a trailer.
Good luck!
