Results 1 to 25 of 41
Thread: RT Air Scoops
    Active Member Brogers57's Avatar
    Jun 2013
    Winchester, KY
    Default RT Air Scoops
    Got em installed! Excuse the mess! Followed Doc's & BRP instructions. I did have the dealer cut it for me, was well worth the $50 they charged me. Cannot wait to test.
    2014 Black RTS SE6
    2012 Black RS - Sold 7/24/2014
    2011 Sonata LTD
    Default Congrats. ..
    You will be able to tell. Most have been quite happy with the results...but you will let us know..
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Nov 2012
    North Las Vegas, NV
    They worked well on our 2012.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Active Member viperryder's Avatar
    Oct 2011
    Ohio
    Default Air scoops
    Installed them on my 2014 RTS and have been happy ever since. You will find that the heat is no longer in your glove box or between the glove box and seat. MUCH cooler.
    2011 RT-S SE5 Viper Red
    2014 RT-S SE6 Cognac
    Bajaron sway bar w/ aluminum heims
    Custom Design HM Brake light
    Custom Design Red front fender lights with turn signals
    Lidlox
    Corbin arm rests
    2014 RTS SE6 , Cognac
    Nov 2013
    Central Texas
    They do work. Interesting how such a simple thing can make such a difference. I know that they - along with the other work done as part of the 2013 RT recall - made a huge difference with the heat problems on my 2013 RTL. You will be glad that you did it.
    May 2014
    Benson, NY
    Default Covers
    Make sure the plastic caps that cover the holes for the two bolts are seated properly. They are a little bit of a bugger to get clipped in. I saw a lot of pictures of the new vents and those covers were missing.
    2015 RTS Special Series
    Russell Day Long seat
    F4 Customs windshield
    Sena 20s
    Active Member Large1's Avatar
    Dec 2016
    Boise ID
    Can I get this Kit in Chrome or part chrome?
    Quote Originally Posted by Brogers57 View Post
    Dick Harding
    Boise,ID
    2011 Spyder RT SE5 Limited
    Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming "Wow! What a Ride!
    Large1 is online now Report Post
    Nov 2013
    Central Texas
    Quote Originally Posted by Large1 View Post
    No, they only come in gloss/flat black. You can, however, paint them to match the color of your Spyder.
    But I've seen some that were painted, and they looked awesome!
    Taxmyzer painted his...
    Jun 2013
    Winchester, KY
    Quote Originally Posted by Bensonoid View Post
    Yeah I pushed and pushed on them. Hopefully they stay in!
    2014 Black RTS SE6
    2011 Sonata LTD
    Jun 2013
    Winchester, KY
    Quote Originally Posted by viperryder View Post
    Sure hope so! Tired of having a hot crotch! [emoji85]
    2014 Black RTS SE6
    2011 Sonata LTD
    Nov 2012
    North Las Vegas, NV
    I just left them off. Black bolts didn't show.
    2016 F3 Limited
    2019 Ryker Rally
    2020 CSC TT 250
    Dec 2016
    Boise ID
    looks like there is a trip to the dealer in my future, Or is there someplace after market I can get them?
    Dick Harding
    Boise,ID
    Very Active Member Y Rider's Avatar
    Oct 2010
    Springfield, MO
    I have a 2011 RTL that I have to park outside the garage after long rides until the gas smell goes away. This happens when the gas tank heats up on longer rides and boils the gas. I am hoping this air scoop kit may solve my heat buildup problem. If I can't get BRP to supply the kit I'll get it from the Powersports Warehouse for $46.89.
    http://www.powersportswarehouse.com/...BRP//219800388
    MODS: Elka Shocks, ESI RT HMT Brake Light, ESI RT Brightsides, ESI Fender TIPS, ESI RIPS, ESI RT Day Runners, Grip Puppies
    AmerSeal Sealant, KewlMetal Kewlock, Scorpio I900 Security System, Stebel Nautilus air horn, KewlMetal Highway Brackets & ISO Wings
    Corbin seat, trunkrest & driver backrest, Capt.Jim's Belt Tensioner, SpyderPops LaBlock, Cat Shields, Bumpskid & Belt Guard
    Seal PUP Floorboards, BRP chrome, Ron's Anti-Sway Bar, Lamonster LED Head/Fog Lights & BRP Air Scoops
    2011 RTL , White
    Dec 2016
    Boise ID
    Quote Originally Posted by Y Rider View Post
    ​Thanks looks like the route to go
    Dick Harding
    Boise,ID
    Nov 2012
    North Las Vegas, NV
    If you haven't already consider removing the 2 splash pans under the engine for even better air flow with the scoops.
    2016 F3 Limited
    2019 Ryker Rally
    2020 CSC TT 250
    Oct 2010
    Springfield, MO
    I removed the two splash pans a couple years ago. It helped a little but not enough. Hoping the air scoop kit is the answer for my heat problem.
    2011 RTL , White
    Jun 2013
    Winchester, KY
    I'm sure they will. Just by looking out the outline of these and how their installed it only makes sense that everything will be cooler. [emoji1303]
    2014 Black RTS SE6
    2011 Sonata LTD
    They have to be oriented correctly. Then they will pop in easily.
    Jun 2013
    Winchester, KY
    Yeah their in. Just extra pushing to ensure they don't fall out [emoji851]
    2014 Black RTS SE6
    2011 Sonata LTD
    May 2009
    Connecticut
    A few of us were Telling BRP in these threads a few years ago that the Acoustic Panels OVER the cylinder heads did NOT make a whole lot of sense BUT it kept the sound down some? It proves they do listen- sometimes- If you do put on the Vents Make sure you Put the Kit Braces where the acoustic panels once were or ???
    Sea Doo GTI-SE 90 Jet Ski!!
    Jun 2013
    Winchester, KY
    Quote Originally Posted by Sarge707 View Post
    The foam/heat tape was applied!
    2014 Black RTS SE6
    2011 Sonata LTD
    Very Active Member Zip's Avatar
    Sep 2016
    LI NY
    Thank you for the link but there is no photos. I like to see what i am buying before I buy it. Do they have photos anywhere?
    2010 RTSM5
    2010 RTSM5 , stock Stock Silver
    Jun 2013
    Winchester, KY
    Quote Originally Posted by Zip View Post
    I bought my kit from there. Sadly i've not been able to find a picture of the kit yet. Shipping was a little slow (Took about a week to get it out) and way over priced IMO but I think they lower their actual product price and charge higher shipping, still under $70 and cheapest I could find.
    You'll get the following:
    1 x Bag of screws, bolts, nuts and caps
    2 x scoops
    2 x scoop covers
    2 x scoop front fins
    2 x structural bars
    2 x foam pieces with heat tape already applied.
    Get your BRP and walk through from Doc Riverside. I had my dealer cut my panels, only cost me $50. They already have the tool and what some may call a template supplied from BRP.
    2014 Black RTS SE6
    2011 Sonata LTD
    Active Member ZDarkman's Avatar
    Jun 2013
    New Jersey
    Default 2012 RT, Template for Air Scoop and Instructions?
    First of all, I want to thank EVERYONE for sharing their info.
    I have a 2012 RT-S and I just received the Air Scoop Kit, I believe everything is here, scoops, screws, and the 2 structural bars.
    Does anyone have the instructions and the template for installation. At this time, I rather do this myself. Will probably use a dremel tool to do the cutting. But I just want to get as much information as possible just to make things easier. Any help will be deeply appreciated.
    My email address is zdarkman@gmail.com
    Thank you.
