SPYDER HORN UPGRADE
I was thinking of changing out my stock horn on my 2015 Spyder. I would like a deeper tone. I don't need a air horn. I'm looking for simple installation ( I know, Aren't we ALL). Anybody got information on this.
Doug
Wolo
Wolo was very easy to install. Lots of threads on this. Wolo (419) Bad Boy Air Horn - 12 Volt https://www.amazon.com/dp/B000F5DQWY..._wZDRyb5BBHDBC
Rawhide Kid
2014 Spyder RT Limited. Cognac
Goodyear, AZ
Wolo
I got the Wolo from Spyderpops comes with mounting hardware and is simple 2 screws and 2 wires. Wires have ends already, unplug one, plug in the other. Great set up, no more beep beep. Great safety upgrade.
I have a WOLO. Plenty loud!
Sent from my SM-G920V using Tapatalk
WOLO horn
I just installed one so simple I had to find something else to do to stay outside away from sister in law easy job 15 minutes or less
Other Wolo.....
Has anyone tried these?
The Critter 2016 RT-S
Cat Bypass from Lamonster
BajaRon Sway Bar
Hella dual horns with relay
BRP Hitch with trailer module
Foam Grips
Adjustable Air Deflectors
Shorty antenna
Ultraguard half cover
Gremlin bell from my son
Try this....
Your local autoparts store. They have some louder ones similar to the stock ones easy swap....
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
Check out the Wolo 619, same size as the 419 but a tone like a tugboat!
john
Dumb me, I figured to save myself the trouble of installing a WOLO myself, and let the dealer-who-shall-not-be-named (I don't go there anymore) install it while the recall work was being done on my 2013 RTL. I supplied the horn, relay and in-line fuse. When I went to pick up the Spyder, I was presented with an invoice for 3 hours @ $99.00/hour to install the horn. I could feel the volcano in me ready to erupt, but kept my cool. I asked to speak to the owner of the dealership. I very calmly explained that there was no way it could possibly take 3 hours to install a horn. He offered to cut the labor time & price in half. I offered to call the DMV and report them for price gouging. He then offered 1 hour. I pulled out my cell phone, looked up on the wall where the required shop rates, etc. along with the complaint number for the DMV are posted, and started dialing. He then very quickly offered to wipe the slate clean and not charge me anything for the install as a "goodwill gesture" because I was such a "valued customer". I started to ask him why, if he was willing to do it for nothing, try to charge me for 3 hours labor, but I kept my mouth shut, walked away, got on the Spyder, rode off and never looked (or went) back. Amazing what some dealers will try to put over on their customers.
2017 Champagne Metallic RT-S SE-6 Rivco Dual Flag Holders; Slingmods Highway Pegs; (Hate Them) Airhawk Seat Cushion; Show Chrome Black Touring Rack w/ Risers & Touring Windshield; RAM X Mount For TXTAG; TackForm Phone Mount; Lidlox; Magic Mirror Mounts; Guardian Bells; WOLO "Bad Boy" Air Horn; Dual USB Power Outlet With Voltmeter; Spyderpops Full View Mirror Turn Signals; Large Brake Pedal; Kott Grilles; Large Mud Flap; BajaRon 3 Piece Sway Bar, Last But Not Least, Kuhmo Rear Rire, Vedrestien Fronts.
The 2013 RT is a bear to install an after market horn in. When I did mine there were only two really good options I could see, add trumpets and squeeze the compressor in above the oil tank, or install something like a Bad Boy in place of the OEM horn. Neither option was a straight forward simple job! I went with the trumpets. I liked them so well I did the same thing for my 2014 even though there is plenty of room where the oil tank was in the 2013.
Your dealer may have screwed you, but I would say nowhere nearly as bad as you think he tried to.
I did the same with the Stebel Nautilus. First farkle I added! Safety first.
Sent from my SAMSUNG-SM-G890A using Tapatalk
this posting has been vetted, scrubbed and endorsed by the committee for postings
Hi George!
They usually need the relay in order to get their "singing voices" up to full song...
Ordered mine through Spyderpops, super loud.
Sent from my iPhone using Tapatalk Pro
Shooter
__________________
Steve Chamberlain
2017 F3 Limited
Little Elm, Texas
972-467-8077
