2014 RT Defective engine casting
I am currently looking to purchase a very low mileage 2014 RT Ltd, Black Currant color.
Recently, however, I learned from a 'reliable' source that there was a run of 2014 RTs, which had defective engine castings, which would eventually leak oil and require 'Bondo' patching. I understand that these bikes had to be returned to BRP - incidentally, these were of the Black Currant color as well.
Is this a valid report? Steve(of BRP), if you read this post, will you please respond, concerning it's validity? If true, might I then send you the VIN of the RT in question, to determine if its engine was involved?
Thanks, Fritz
I know of one machine this porous casting happened with. Forgot the color.
As for a Bondo patch, that I never heard before. The machine I mentioned above was repaired by engine replacement.
There may have been others, but the problem seemed pretty rare and random.
We have an early 2014 RTS, purchased in January 2014. I have tried to keep aware of known issues since it was the first year for that series.
The known concerns were the ignition switch / key recall by key code number. This involved replacing the ignition switch because the key got stuck. Some engines had a slight oil leak from the oil galley setscrew plug. This was addressed by removing the setscrew, properly cleaning the threads and installing a new setscrew after priming with Loctite and installing wet with a Loctite product. The most concerning issue with a 2014 model is DESS issues.
Outside of that you still contend with known low quality tires which is an issue for all years.
When looking for a 2014 Black RTS, you may find it better to go by the build date if the porous cases are still a concern. Those early machines should have 2013 or very early 2014 dates. The build date is on the sticker, near the drive belt, on the swingarm.
One bike doesn't indicate a pervasive problem...
Maybe I did not convey that, but my thoughts 100%.
No doubt be diligent with good upkeep, but I think a problem of this sort would be well sorted out or exposed on a specific bike by now.
Also, my linking was to show engines had been replaced, not a Bondo patch.
Glad mine is White!
Jack
2015 BMW R1200R LC
2014 RTL SE6 Pearl White
2012 RT-622 trailer viper red
2011 Polaris Ranger green
2016 Can Am Maverick
2014 rt owner
Love mine 13k miles no probs
Sent from my SAMSUNG-SM-G920A using Tapatalk
Let's see....
Not to be confused with the run of spyders that had the engine cover bolt that caused some leaks...that was a quick fix. Otherwise have not heard of any casting problems.... and this would be the place to hear it....
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
I have a 2014 Black RTS limited with 25,000 miles on it still going strong.
Mine is "Orange", and everything is still "Tight & Right"!
STEVE - BRP - are you out there? I attempted to send a message to BRPcare, with the VIN number, but got the reply that BRPCARE does not respond to private messages. BRP - I won't proceed with this purchase, unless I receive a definitive answer from you.
The build date on this bike is 4/20/2014. Incidentally, this bike(2335 miles) was bought at auction in Texas, and is now at a dealership(non-CanAm) in Missouri.
Use the following address: brp.care@brp.com
They do not answer PM's sent to this site.
OIL LEAK
Thanks, Fritz
" BONDO " patching ...reliable source ???? .....like others have indicated, IMHO this comes under the heading Urban Myth ..... or " if you heard it on the internet - it must be true " sort of thing ........Mike
THANKS
Just Traded My 2014 RTL
Thanks, Fritz
I just traded my 2014 RTL Pearl White for a 2016 RTS Special. The Can AM Tech said it was in great shape. I've never had any leaks, never added oil between changes @ about 5000 mile intervals. traded with 21000 miles. Never heard of any issues, other than an initial leak in one set screw.
2016 RTS Special Triple Black, BRP Freedom Trailer, Spyder Pops Rear Lighting Kit, Spyder Pops Full view Turn Signals, Trunk Light, Rivco Highway Pegs. Doc's Spring Tensioners, Trunk Organizer, Magic Mirrors, Foam Grips, back to Stock Windsheild, Lamonsters cat delete, Bajaron sway bar, More Farkles to come !!
My machine also received an engine replacement due to leaking in the casing. I won't lie about the experience as it wasn't fun and wasn't needed at all. Took about 65 days from start to finish. Everything is working fine at this point.
2014 Black RTS SE6
2012 Black RS - Sold 7/24/2014
2011 Sonata LTD
This was not my issue with ending my relationship with CanAm.
2015 RT Limited Intense Red Pearl
Wrote BRPcare and gave them VIN and Build date - no response yet.
Can you tell me the build date on your RT?
Bike I am looking at has build date of 4/20/2014 - date found on label on swing arm.
2014 Black RTS SE6
2011 Sonata LTD
05/2014
One thing to note, it sure did suck to go through all that but I love my bike. Things do happen sadly.
2014 Black RTS SE6
2011 Sonata LTD
