Need Help - Idles rough then smooth + codes
2011 RTL / SE5 having issues. Idles roughly at start up then smoothes out for approximately 7 - 10 minutes before shutting off. Showing codes P2279 an P0106. Would like to hear from the group before taking to the dealer.
2011 RT LTD /MODS: Seal Floorboards, Elkas, SpyderPops Bump Skid and Block off plate, HMT Brake light, BajaRon's sway bar, Heim Links, Diamond R's passenger armrest, Utopia driver backrest
P2279 is intake air system leak & P0106 is Manifold absolute pressure circuit range/ performance. Not sure what the fix is though.
2008 Triumph Rocket (SOLD)
2002 Honda VTX 1800 C ( SOLD)
Could be the vacuum hoses around the throttle body. They suffer from heat, crack & you get air leaks causing rough running.
2008 GS SM5, Full Moon Silver
2007 Piaggio MP3 - 250cc
ALSO.....
Check the intake boots/manifolds for the throttle body. They do the same thing but start with the hoses shown above. Quick check for the manifolds is the Rev the engine and spray WD40 around them. If the rpm's change they are leaking and high temperature silicone will be a temporary fix till you can change them...
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
M109Dreamer - thanks for the info. Is this on the right or left side?
The hoses are on the left side. You can get to them without taking the air box off, but it is tight. How many miles on you bike? If it is time for spark plugs and wires, take off the air box. Change the air filter while you are there.
Get the plugs and wires from BajaRon.
1998 Honda Valkyrie
2006 Mustang GT. Varooooom!
US Navy Veteran
Member: American Legion
so that is the left side when i am siting on the bike right ?
Vacuum Hises
So, I have found that my front hose is definitely cracked wide open and the other one has sura e cracks. The back hose looks like it is easy to replace; however, the front one is a pain. Do you have to loosen the Bosh Controller to make it easier to replace the front hose or is there some other way. Do I have to remove the air box?
Originally Posted by M109Dreamer
Yep, if you havent replaced to 2 hoses. They are way over due. I just did our 2011 RTS last week. They are the 2 red hoses in the pics. I used the napa lines.
And this is what my stock lines looked like from an 2011 RTS w/ 15k miles
Sent from my SAMSUNG-SM-G920A using Tapatalk
When you replace the hoses: use high quality silicon hose of the same size. It'll outlast the bike!
You might need a needle nose pliers to pull the old hose off. If it still wont budge use a knife to slice the side of the old hose at the fitting. Use the old hose as a pattern to get the exact length when you cut the new replacement to length. It's not as difficult as it seems.
Sorry, for the late response I'm not on very much anymore since SL doesn't support TapaTalk. You don't have to remove anything, just either cut the old ones off or what I did was twist the lines to brake the seal and then they just pulled straight off. When you do replace them you will want to make sure that you use the same length of tubing. I just took the old ones off and measured those and then just cut the new tubing to the same length.
2007 M109R LE - To many MODS to list. Its cheaper that way!!!
Where did you get that air filter assembly from? Do you have the brand and part number?
Get the kit here
http://spyderstore.com/index.php?rou...ory&path=59_68
2021 Sea To Sky, 2020 RTL
but our benefits don't?
SpyderLovers Sponsor
K&N air filter. Go to their website, order it. NAPA has the vacuum lines in silicone.
Joe Meyer
I would also check the purge valve for proper operation.
New to Sue and I
Gone but not forgotten
RTS 2011 SM5, 95,000 miles
what is the purge valve / Thanks
Other than the plastic covers you don't have to remove anything to remove the hoses. I did have to use long nose pliers to get to the front one. Be as careful as you can as you need to cut your new hoses to the same length as the old. I bought my hose from NAPA.
Reason: then (time) - than (other option)
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
And remember that you are asking questions to a post that was started 2017
no matter how old these threads are they are a wealth of knowledge!
The purge valve is the valve that lets your gas fumes from the gas tank into rear cylinder. If this valve fails it will cause motor to run on one cyinder, or eve stall on startup. Once cylinder is purged it will run ok. Sometimes it will reqire restarting tbe bike 3 or 4 times. This would happen to me if my gas level was below a half a tank of gas, and motor up to temp. If i stopped for gas when gas was low i never had a problem, because tank would vent when i put in fresh gas.
This valve is located on the right side of bike. It is attached to rear cylinder. Some have had luck by removing hose and blocking of inlet to valve. Others have removed tge charcoal cannister along with blocking of valve. Do not unplug valve, na ny does not like that. Do a search on "cannister removal". Bruce
New to Sue and I
Just got in with check engine light 2012 RT 3400 miles Code P1171 ( #1 lean) Ill check vacuum hose and run seafoam..I've only driven a 100 miles since I got it last week and it was running a lot different until tonight. Like a small miss at low rpm..fine on the highway but ...engine light is annoying. Should i just disconnect the neg battery post to clear once i check over everything?
Reason: Link
Originally Posted by davev1pa
Any word from ur dealer?
Little should get back soon & better details will post as I know.
