Results 1 to 12 of 12
    Active Member spyderwoman's Avatar
    Sep 2007
    morganton,nc
    Default Xm radio install on 2014 RT ..?
    Need any help or info I can get on installing the xm satellite radio on a 2014 RTL . Like where does the module mount and where does it connect to the harness ?
    Jul 2011
    Mitchell, Ontario, Canada
    I will assume you are talking about the XM radio kit from BRP. It plugs into the entertainment harness if you have it. If not you need that as well.
    Here are the instructions from BRP.
    http://instructions.brp.com/content/...mber=219400610
    http://instructions.brp.com/content/...mber=219400612
    Sep 2014
    USA
    It. Would be a lot cheaper to get a external unit and plug it in at the trunk
    Sep 2007
    morganton,nc
    Looks like the whole back rest section will have to come off just to put the harness on . A little confused about the module , instructions read it mounts next to the battery ? Maybe a misprint..
    Jul 2011
    Quote Originally Posted by spyderwoman View Post
    Since the instructions are for all RTs'. Older models have the battery in the rear left side.
    Sep 2007
    morganton,nc
    Ok..thanks for the help
    Active Member woodyaa's Avatar
    Mar 2015
    Harvard, Il
    I installed one on a 2015 RTS, the xm module mounts on the left side behind the saddlebag. There is a pre-drilled plate there that leaves it in the wind to cool it. Good luck!
    Sep 2007
    morganton,nc
    Did you have to run the harness also ?
    Default A MUCH LESS EXPENSIVE OPTION !!!!!
    I don't think Bob Denman saw your Thread on this, but I would PM Him and ask about the XM system He put in His RT. He likes it a lot and I doubt it cost anywhere near what the BRP one cost.......... Mike
    I think that was changed with the '14 or '15 model year so you don't have to take the back section off. That actually is not an overly hard job to do, but it is more than just a couple of hours!
    Mar 2015
    Harvard, Il
    I had to have the entertainment harness with the factory xm unit.
    Sep 2007
    morganton,nc
    Have the harness and radio . My husband is going to try and install them for a friend ..just trying to gather as much info as possible.
