fault codes display
I forget...has anybody else tried this?
Turn the ignition switch to "on"
Clear the warning message with the mode button on the left handlebar
Use the mode button to select the "Hr" mode (it must be in this mode),
Depress the headlight override switch on the right front handlebar
and the mode switch on the left front handlebar at the same time
While holding these two buttons in, quickly hit the high beam flasher button on the the left grip five times in quick succession
The fault codes should scroll across the instrument panel and you can relay them to the dealer.
yeah thats how you can get the fault code and if you have the manual you can look up the code meaning. I have used it to see what the fault was when I had the brake failure notice scroll across my display....
Diggittt
Full Moon #1176
Talon Alarm
Trunk Spring
Power Bus
H.I.D. Headlights
Kuryakyn ISO Grips
NMN Highway Brackets
Kuryakan Highway Pegs
Two Brothers Dual Exhaust
BRP Sports Rack & Back Rest
LED Fender Tips
Ride-On
BRP Tank Bag
H.I.D. Fog Lights
Sirius Satellite Radio
GlowRyder L.E.D. W/Remote
TricLed Fender Lights
If the engine is running, you do all that you said, except you do not need to depress the headlight override switch.
Bob
MOgang Member
So you are saying we do not need to do the headlight override switch? All is needed is to hold the mode switch? Am I correct?
And the engine is running right? I mean after you Clear the warning message with the mode button on the left handlebar? Or do you need not to start the engine?
Bob
The word IF above kind of confussed me thats why I asked.
Thank you
Joe
Bob
Thank you
Joe
That's correct. Clear the warning message, start the engine, (assuming it's not an engine problem), depress the mode button on left handlebar and flash the headlights 5 times.
Bob
This is such useful information that I printed it and put the page inside my owner's manual, so that it would always be readily accessible.
Thanks go to you all!
Frank
Bob
Sorry, but I did forget to mention that you have to have the Hr mode screen showing. (just work your way through the different modes with the mode button on the left handlebar until the Hr mode is showing ).
Bob
