Results 1 to 21 of 21
    Active Member SteveandBelinda's Avatar
    Canton, MI
    Default Trunk replacement shock on RT trunk
    Anyone know of an equivalent replacement shock for the trunk on a RT 2010 & up? Don't want to rig something up, I want to replace it with another equivalent one.
    I am in contact with some manufacturers, and trying to find something, but nothing solid yet. Suspa wants $95, Cheapcycle.com wants $59.99, and Can Am the same, but want cheaper. Have a manufacturer that will do it for $42.61, but still feel that is too high.
    2014 Can Am Spyder RT Limited - Pearl White
    2010 Can Am Spyder RT - Full Moon
    Very Active Member M109Dreamer's Avatar
    Mar 2011
    Jackson, MS
    I found off of a web site that someone listed. I also an running the dual struts now. I would recommend the dual strut if you keep anything in the lid behind the nets or if you use a rack. Ill see if I can find the thread.
    Sent from my SAMSUNG-SM-G920A using Tapatalk
    2007 M109R LE - To many MODS to list. Its cheaper that way!!!
    Mar 2011
    Jackson, MS
    Here ya go.
    http://www.spyderlovers.com/forums/s...ad.php?t=93228
    Finless figured out a really cheap way to improve things.
    (Yes: you've got some "DIY" stuff to do...)
    Why not PM him, and get the information?
    Jan 2015
    southern WI
    If you simply drill a new mounting hole for the lower stud, it'll hold it up, and it's free. Drill a new hole 3/4" above the existing hole. It holds the lid up more vertical and lets the strut remain fully extended where it's strongest. Worked for me. I don't use a net, but I do have a rack on the lid.
    2016 RTS , Pearl White
    Mar 2011
    Jackson, MS
    Quote Originally Posted by Mazo EMS2 View Post
    Are you using the stock size struts? I would live to be able to use the 2 strut set I have now and be able to raise the lid higher.
    Sep 2016
    Lewiston , Maine USA
    Default Dual Struts for Trunk?
    Is this a diy mod? If so, can you tell me part numbers and where to order one? Please? Thanks
    Jan 2015
    southern WI
    Quote Originally Posted by M109Dreamer View Post
    Yes, it's the stock strut.
    Mar 2011
    Jackson, MS
    Awesome. Gonna have to mod our lid then
    Canton, MI
    Here's a post that says there is a guaranteed BRP replacement for $44.00
    Alan Salz: Exact fit with lifetime warranty. Used this one on my 2011 RT with no issues. Also available from Amazon:
    https://www.amazon.com/708300383-Replacement-Lift-Support-Can-Am/dp/B01MDPI3O9/ref=sr_1_fkmr0_1?ie=UTF8&qid=1484976834&sr=8-1-fkmr0&keywords=PM3300+gas+shock
    https://www.liftsupportsdepot.com/li...-lift-support/
    Mar 2015
    forrest above Reno, Nv
    Thumbs up Outstanding fix
    That's a great fix. It will be done today as there are feet of snow around here and more coming.
    Bad snow plow drivers cause ----------Kaos
    2014 RTS , Circuit Yellow
    Oct 2014
    Fort Mill, SC
    I just did the mod that Mazo (Post #5) did. It worked great.
    I had installed a Show Chrome luggage rack that caused the trunk lid not to stay up. This mod was just enough to hold the lid up again. You will not be able to add much more weight, but for now it is fine. Cheap and Clean fix.
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    Member: American Legion
    Mar 2015
    Thumbs up Done and done!!
    Us '98 Valkyrie guys gotta stick together!!! Also have a rack back there but the trunk lid just barely stayed up. Much better now It's a little higher too.
    Kaos
    Canton, MI
    Fixed ur up. Bought an identical shock that is better than the OEM, and works better. Here's a pic of both shocks, along with reciept, address & phone number of the place I bought it and the price of $44. Also included pic of final installation.TrunkShock1.jpgTrunkShock2.jpg
    Very Active Member finless's Avatar
    May 2013
    Stanton, ca
    Quote Originally Posted by SteveandBelinda View Post
    Where did you get the mounting hardware?
    Bob
    2011 RT-S SM5 - Black
    Canton, MI
    What mounting hardware? All I did was take the old one off of the ball joint at the bottom, then took bolt & nut from the trunk lid end (watch you don't loose the spacer that goes into the eyelet. The only hardware was the shock itself, and that is all the info on the receipt underneath it.
    Very Active Member HayRog's Avatar
    May 2013
    Sacrament0, CA
    Finless maybe thought, as I did, that you were mounting a second strut. In that case, additional mounting hardware would be needed.
    May 2013
    Stanton, ca
    Quote Originally Posted by HayRog View Post
    Yes that is what I thought....
    Bob
    Registered Users lou49's Avatar
    lake mary fl.
    Wonder if it would work also on my ultimate seat!
    Canton, MI
    No, but I should have a post with a video, where I replaced the old seat (stock RT Limited) with an exact one, but more pressure. Now all I do is turn the key to raise the seat, and it pops up all by itself. The thread also show the receipt and company that I bought it from, I think $19 or something cheap. I will look for the thread and post it here if I can find it.
    Quote Originally Posted by lou49 View Post
    Dec 2015
    Oakley Utah
    Good idea. I'm going to have to try this.
    2014 RTL Platinum
