Results 1 to 13 of 13
    Dec 2016
    New Bern NC
    Default Fuel Gauge Problem
    The analog fuel gauge on my 2014 RT-S is showing empty and I get an orange warning on the display and a fuel warning light, but the tank is filled. Has anybody else had this problem? Any ideas on how to fix it? The bike has less than 5k miles on it and is like new all over. Just bought it two months ago, so I'm still learning the systems. Any help much appreciated.
    Phil Bowie
    www.philbowie.com
    Jun 2010
    Las Vegas
    Sounds like the float is stuck. Are you still under warranty/extended warranty?
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Dec 2016
    New Bern NC
    Thanks SpyderAnn. Feels like an electrical glitch, though. I had the problem a few days ago, and thought the tank was empty, so I put in five gallons with a portable can. The gauge returned to full and I thought all was OK. Then today I started it (with a full tank) and watched the needle slowly fall to empty again, with the warning lights coming on.
    I think that it's time to give your dealer a call...
    I'm sorry that you're having trouble with your bike; good luck, and please let us know what happens next.
    EDIT: I just saw your reply to Ann...
    Isn't there an electrical connection at the top of the tank for this sort of stuff?
    Make sure that it's plugged in nice and solid.
    Jun 2016
    Phoenix
    Take the screws 4 screws out. Remove the plug from both temp and gas gage.Do you get an indicator bar graph on each side of screen? I could get my fingers back there without pulling the screen completely out.
    Very Active Member SteveLaoyster's Avatar
    Nov 2015
    Myerstown, Pennsylvania
    Default Wires...
    You might want to pull the dash bezel to check the wires on the back of the gauge. Just 4 screws then pull it towards the handles. Be careful as the coolant temp gauge comes with it too. Good luck.
    AKA Jud Smales, Four Year Spyder Ryder!
    "Quando Omni Flunkus, Moritati"
    The Critter 2016 RT-S
    Cat Bypass from Lamonster
    BajaRon Sway Bar
    Hella dual horns with relay
    BRP Hitch with trailer module
    Foam Grips
    Adjustable Air Deflectors
    Driver & Passenger Gel Pads in Seat
    Shorty antenna
    Ultraguard half cover
    Gremlin bell from my son
    Break Stripe Kit from Wrap My Spyder
    2016 RT-S , stock not yet Pearl White
    Dec 2013
    That sounds like the wiring for your sender unit on the tank has somehow come off or otherwise failed; or the sender unit itself has fallen apart inside the tank; altho I guess it could also be just the gauge that spat the dummy.
    One way to check/confirm if it's a failed sender unit or dud wiring is to pop the dash open & disconnect both of the analogue gauges - fuel AND temperature. Label or otherwise identify the wires & secure them out of the way, then put the dash back on properly & start your Spyder up, maybe even take the opportunity to go for a ryde around the block. If the digital gauge displays for both fuel level & coolant temp work OK, then it can't be the sender or its wiring. But if you have exactly the same problem with the digital gauge, ie it shows empty when it's full & displays the warnings, then it's most likely going to be the message from the sender unit either not being there at all due to a wiring problem or the sender has failed or fallen apart inside the tank! Your first step then should be to check that the sender unit is still plugged in to the wiring loom with wires that aren't shorted or otherwise compromised.... & that might need you to remove a bit of tupperware! If it's not that, then you may be faced with having to remove the sender from the tank & either fixing or replacing it!
    If the wiring is good & it's all connected & working properly, so you get to the 'pulling the sender out of the tank' stage, don't get suckered in by everything looking fine at first glance - you really need to check it all carefully! A tiny worn spot in the 'quadrant' used to show the level can make the float stick or not read properly, altho sometimes this sort of failure can also be attributed to a float that no longer floats (ie, it's got a hole in it so now it sinks instead of floating to give you a level) but I'm not sure that Spyder sender unit even uses a quadrant or a float to determine the fuel level, those 'old school' devices are becoming less prevalent these days! Anyhow, good luck getting it sorted whatever the problem may be. I hope this helped some!
    Default Agree...
    if you manage that and it still not solving the problem you will have to go to the dealer. Now if your under warranty I would let them deal with it...
    ​2012 RS sm5
    Dec 2016
    New Bern NC
    It's not still under warranty, so I'll try to fix it myself.
    I'll do some very careful digging and let you know what I find. Thanks for the advice, all.
    Phil B
    Active Member Spyderjuice's Avatar
    Aug 2008
    High Point, North Carolina
    I had this problem on a 2008 GS. It was showing full when it was empty and empty when full. The problem was the float on the fuel pump and the fuel pump had to be replaced.
    Stan
    Happy owner of 2014 White RTS - SE6
    Dec 2016
    New Bern NC
    Thanks again for all this great advice so promptly. I will indeed check with BRP to see if I'm covered under the extended warranty.
    Phil Bowie
    Jun 2022
    North Dakota
    Did you find out what the problem was?? as I'm having this problem now. Briteyes asking
    Dec 2013
    Quote Originally Posted by Briteyes View Post
    If you follow the steps I outlined in that post you quoted, you should be able to narrow down any likely problems &/or either fix any pump/sender issues or swap over to the digital gauges all the time, if you have analogue gauges fitted. There again, have you tried anything suggested in the other thread where you asked about the low fuel light & fuel gauges??
    https://www.spyderlovers.com/forums/...81#post1641181
    But as far as this thread is concerned, I don't think Phil ever came back to tell us wwhat his eventual outcome was - but he's been around the Forum fairly recently, so maybe he'll reply with an update??
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
