Results 1 to 15 of 15
    Active Member acpd22's Avatar
    Nov 2016
    Ashland City, TN
    Default F3 Limited Trailer Wiring
    Well my hitch came in today but the search continues for the Isolator that is compatible with the Limited. Any help would be appreciated!
    Nov 2016
    Ashland City, TN
    Default Bump!
    Bump
    Active Member fencepost's Avatar
    Apr 2010
    Thorn Hill, TN
    Contact Lewis @ Electrical Connection, he used my F3T for the prototype.
    SpYderman
    Active Member KJWEB's Avatar
    Jun 2015
    Midland, TX
    Did you purchase a 3rd party trailer hitch or the BRP hitch?
    www.sasspyders.com
    2016 F3T
    2015 Freedom Trailer
    Sypderpops BumpSkid Plate
    Lamonster ISP Key Cover
    Lamonster F3 Bar Clamp and Power Port
    Lamonster RIP floorboards and frame caps
    Lamonster Chevron Highway Pegs
    BajaRon Swaybar & Heim Links
    F4 Custom 21" tinted windshield
    BRP Cannonball Seat
    BRP F3 Idler Pully
    FOBO TPMS
    LidLox (dual)
    Garmin 660LM GPS
    Cat Delete Performance Pipe
    F3T Top Case
    PPA Black Widow Wheels
    Custom Frunk Wrap
    Very Active Member ABQSpyder's Avatar
    Jun 2013
    Green Valley AZ.
    There's a plug n play harness on E-Bay a Canadian company who also sells hitch.
    Jun 2015
    Midland, TX
    The F3T or F3T Limited trailer kit wire module is different from a F3 aftermarket hitch and wiring.
    www.sasspyders.com
    2016 F3T
    BRP Cannonball Seat
    BRP F3 Idler Pully
    FOBO TPMS
    LidLox (dual)
    Garmin 660LM GPS
    F3T Top Case
    Custom Frunk Wrap
    Jun 2013
    Green Valley AZ.
    http://www.ebay.com/itm/Can-Am-Spyde...lXmPsh&vxp=mtr
    Says it will fit a F3-T 2016. They also have a listing for a F3. I guess they are wrong??
    It's at least worth a call.
    I bought a hitch from them for my 2015 F3 nice product.
    Nov 2016
    Ashland City, TN
    Default Hitch
    The hitch I purchased was a Show Chrome. I had inquired on here whether anyone thought it would fit the F3 Limited and I was told by a member that it would. The answer to that question is yes and no. No, it will not go on like the directions state (BTW, it does state in the directions that it will not fit F-3 models). Yes, it can be made to work. It will have one less bolt than what it was designed to have but it could be drilled for the third bolt on the right side of the bike. I left it with just two bolts for now. I will be pulling a Tag-along so I don't think that it will be an issue. Feel free to comment as you will.
    Jun 2013
    Green Valley AZ.
    Thought you were looking for a wiring harnesses.
    Jul 2011
    Mitchell, Ontario, Canada
    Quote Originally Posted by acpd22 View Post
    Could you explain in detail why you can't get all the bolts in the hitch or take some pictures of the problem. Since the swing arms are all the same across all models except F3. I don't understand why it won't fit on a F3 Limited.
    Active Member Smokes's Avatar
    Jan 2017
    Melbourne, Australia
    I'm guessing as I'm going through the same process myself, but I suspect that it won't directly fit an F3 LTD because the radio/audio system already uses the required power connector under the pillion seat. I'm guessing that the power wiring needs to be spliced at this point to run the trailer.
    Good luck.
    Andrew
    Melbourne Australia
    2016 F3L Spyder
    Now, wash your hands
    Mar 2013
    Maumelle, AR
    That's why it's always best to buy a BRP hitch. No headaches.
    2020 RT Limited , Chalk
    Nov 2018
    Texas
    Default Light harness
    I have a new 2018 F3 limited and I have called all dealers and can't find a trailer light harness I called BRP in Canada lol said to call the dealers
    Jul 2011
    Quote Originally Posted by raysproshop View Post
    Don't know why you can't find one. It shows on the online catalog as available. That means it in stock. So just order it. Or are there details you are not telling us or I am missing something.
    https://www.brp.ca/on-road/shop/spyd...d-rt-2018.html
    Mar 2013
    I just finished installing the BRP hitch from our 2014 RT onto my wife's 2018 F3L.
    Here is a list of items needed for the wiring.
    #710003903 Module
    #710005823 Module harness
    #710004851 Trailer harness
    #207144060 M4 x 40 Screw
    #250100143 M4 panel nut
    #233261494 M6 flanged nut
    #250000722 M6 x 20 screw
    #518321570 Open clamp
    The first three items are for the wiring from the bike to the trailer. The rest is to secure the wiring to the bike ( I did use cable ties that I have). The hardest part is running the trailer wire from under the seat to the bottom of the left saddlebag.
    You can pull up the BRP instructions for Roadster Kit #219400852 Trailer Hitch F3T and Limited from BRP, or Lamonster Garage website (this is where I pulled it from)
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
