2015 F3S stiff clutch pull
Can anyone recommend a fix for the stiff clutch pull on my 2015 F3S? I'm tired of having to find neutral at every stop light or getting cramped left hand. I recall Lamont discussing this but my dealer knows nothing of it. Help?
Little checking..
Google " clutch assist on spyder F3" and you will get some hits. Check with Lamont as well but there is a kit to help. The older models like my 2012 RS came with the assist making the clutch softer at slow speeds or stopped...
yep Spyders have tough hand clutch. I tried one in the showroom and that was enough to stay away from the manual Spyders. It took less then 15 seconds.
I thought about doing something about it, but procrastination and the passage of time has just made my hand stronger. It really doesn't bother me much anymore.
I also have a 2015 F3 S and I was worried about the clutch but I am almost to where I don't notice it unless I have been on a long days ride or a lot of traffic. I would like to feel the difference between mine and one with the clutch assist.
Give your dealer the info in this Spyderlovers thread.
http://www.spyderlovers.com/forums/s...=1#post1080827
Find someone with a RT manual and try it. RTs' have the clutch assist from the factory.
Same thing with me today. Sat on a used 2015 f3-s. Had all the trimmings but that clutch was too much
2016 F3 Limited
2019 Ryker Rally
2014 Suzuki V Strom 650
2020 CSC TT 250
