Results 1 to 7 of 7
    Oct 2016
    Central Valley, Ca
    Default Baja Ron Bar or Sway Bar for the F3
    I was looking for a comment about the Baja Ron Bar on a F3-S model. Some said it made difference and some said it made it worse. I know the bike has good handling and stability though I do have the nanny system F3-S 2016 model; however, does it make a difference? I know the RT made a difference but what about the F3-S model especially for those who switched from the RT to the F3-S models?
    Jun 2016
    Harrington, Australia
    I've got the 2016 F3-L, and it made a huge difference for me. Think of it as a "stabiliser" bar. Some say the F3 doesn't need it, and I can understand that as the F3 handles well, stock. However, for me, the Bajaron stabiliser bar really comes into its own on uneven surfaces. Previously, I always felt like I was going to spear off into the bush when cornering, or when travelling along a cambered, uneven road. That's gone for me now.
    I have to say that I personally have not seen any comments that it makes handling worse, just that some say that they don't need it. The nanny does not kick in for me any differently with the bar, or without it. If you buy and install it, and you don't like it, you can always revert and sell it here. They are a pretty popular item.
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
    Jul 2010
    Las Vegas, NV
    Default Happy
    I put in a lot of them, and everyone is very happy with it. The folks who say they don't feel the difference don't ride spirited enough to gain the benefit!!
    Joe Meyer
    Jun 2016
    Quote Originally Posted by cptjam View Post
    I find that you can notice the difference whether you are a "spirited" rider or not, Joe. Sure, the stabiliser helps when you ride "spiritedly", but it's that "planted" feeling even at slower speeds that makes me sing Ron's praises
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
    Very Active Member hypurone's Avatar
    Jun 2016
    NorCal - Northbay
    Night and day difference. Mine was very nervous (due to a bad alignment I found out later) and it made a huge difference even with a poor alignment! My buddy has an F3-S as well and he doesn't have one on his, I leave him in the dust on every type of road that requires any amount of "handling" required....
    Chuck
    Very Active Member armyspydervet's Avatar
    Nov 2015
    Occoquan, VA
    I do not have a swaybar. I thought about buying one because of the way my F3-T handled. When at Spyderfest last year, Squared Away did my alignment and it was like a new bike. I'm not saying do not get the swaybar, but from my experience I recommend getting the alignment first and then determine if you still are not happy with your F3's handling. (Still may get a swaybar at some point).
    Chris
    2016 F3-T SE6
    Default As I see it...
    it all depends on how and where you ryde the most. You will be the only one to know for sure but if you can find someone with one that will let you test ryde you will know in a heartbeat....
    ​2012 RS sm5
