Keep rain off my neck
I'm looking for any suggestions on how to keep rain from entering the collar area of my jacket. I wear a schuberth modular helmet and have waterproof gear, but I end up with a gap between the base of my helmet and the top of my jacket collar that I'm trying to cover up. Helmet now fits correctly so I can't have anything bulky under helmet. So far I have found this waterproof balaclava at revzilla that looks promising, but I was hoping to not have my nose or mouth covered and have it thin under the helmet. Anyone using something different?
http://www.revzilla.com/motorcycle/r...va#reviews_tab
2014 RT-S Pearl White
There are helmet skirts that attach to the bottom of the helmet. I've never tried one though, and the one review doesn't look good.
http://www.revzilla.com/motorcycle/schampa-helmet-skirt.
Interesting
Originally Posted by JoAnn R
Thank you Jo Ann, had not seen those before and will check into them. I might also look at modifying the original one I posted and seeing how difficult it would be to remove the mouth and one covering portion.
Rainproof Balaclava
Check out the Winter Touring Balaclava from Alpinestars. It has a waterproof rain skirt. I have worn it many times in the rain and it works well.
2020 F3 Ltd
Spyderpops Bumpskid
Spyderpops Brake/Run/Turn Signal LED's
Lamonster Garage LED Fog Lights and Headlights
2013 ST-S retired 1/9/16 at 25,061 miles
2015 F3S sold at 77,565 miles.
Is it too warm?
Have you found it to be too warm to wear in the summer months, or is it ok? Any issues with the seams irritating you after having it on for a while?
Thanks for the info
No it is very comfortable in all riding conditions. If I don't want it over my mouth and nose I just pull that part below my chin.
2020 F3 Ltd
Spyderpops Bumpskid
Good to know
Great, thanks for that review!
Ride faster! Happy New Year!
otherwise be a vulgar brawl.
Cognac 2014 RT-S
2010 RTS-SE, Orbital Blue
I put my Frog Togg jacket hood on and then my helmet. The hood is thin enough, so that it doesn't affect the fit of the helmet.
Invalid Emails
as retired1 said
Put hood attached to my raingear on first then helmet...never an issue..have worn with 1/2, 3/4 and full helmets... if cold add the bacalava others mentioned. I personally use one from Cycle Gear...Freeze out brand.
My Motto Is:
Live my life in such a way that when my feet hit the floor in the morning...Satan shudders & says "Oh, crap, SHE'S awake!"
Red Stallion: 2016 F3t SE6 (from Pitbull PowerSports/ Springfield, MO)
White Knight: 2014 RTS SE6 and matching 622 trailer (from Pitbull
Ms Spydee: 2010 RT SE5
Old-time riders simply wrapped a small hand towel or scarf around their neck to close the gap between the jacket and the neck. This is based on the ssumption that not a lot of water actually trickles down your neck.
If you haven't already, make sure you put a mudflap on your RT.
the back side aero on these is POOR, and rear tire spray gets sucked up and forward.
No other cycle will soak your neck like this thing.
Flatlander, Navy Veteran, Widower
Loved my 2014 RTS SE6 Pearl white
but have a new love now,
my 2017 RTS SE6 Champagne metallic (Champ)
