LED Lights
Is there a go-to brand that is most commonly used in accenting Spyder RT Limiteds that is reliably?
Hi Tyris! I'm Cindy from Tricled.
Our company has been the leader of custom manufacturer of aftermarket led lights for Spyder and other off rad vehicles for the past 6 years.. We are also vendor here in Spyderlovers.
If you need any help or questions on leds, you can contact me here via PM.
Thanks
Also check out Spyderpops. Between TricLED and Spyderpops, they have you covered for accent lighting. They both carry some different products from each other.
[QUOTE=Cindy-TricLED;1213139]Hi Tyris! I'm Cindy from Tricled.
Thanks
And they give great support on all of thier products too!
Joe
You can't go wrong with Tricled!
Harvey at Spyderpops is also an excellent vendor and supplier of LED lights. I had Spyderpops install my LED headlights and foglights at an Spyder event. And he stands behind has products. I had a problem with my light bumpskid and he sent me replacement LED's , no questions asked.
2008 Triumph Rocket (SOLD)
2002 Honda VTX 1800 C ( SOLD)
Both of the vendors that have been mentioned so far, offer GREAT products, and even better customer service!
Tyris,
I have bought a lot of led's( lights)/and accessories from TRIC-LED for my 2014RTS-SE6, they have excellent customer service, and excellent selection of lights/accessories to choose from.
I have also bought led's(lights) from Spyderpops. Spyderpops has also been at Spyderfest( Springfield, MO) as a vender.
Also, check other venders on this site, on the "Homepage". Deanna
Gremlin Bell
SpyderPops Missing Guard Belt
Ultimate F3 Floorboards
Sway Bar with Links
Rolo Laser Alignment
Half Cover
Show chrome Trunk Shock
We sell Spyder LED Lighting from several different manufacturers. We have had very good luck with TricLed products. The warranty and support we get is superior.
The LED bulbs available are pretty cool and a fairly easy install. If you have not converted I strongly suggest doing it.
I put together a video for the RT LED Headlight Bulb install and also another video for the RT LED Foglight Bulb install. Gives you an idea of what you have to do plus how the LED's look lit up.
LED Headlights or Foglight Bulbs, Can Am Spyder RT (pr)
Will check out vendors here, thanks. I didn't realize there were laws about lights (should have) so now have to figure out what is allowed in Iowa. Thanks for the responses. Dan
Blazing Member
I agree TricLED is a great company that stands behind it's products ! Also check out Custom Dynamics as they also carry a lot of LEDs for the Spyder.
Can any one with Lamonster led headlights chime in and state if moisture gets into the lense since cutting the back of the housing is needed to install them.
I just purchased a set of LEDs from Lamonster but I just read on the tricled site that cutting into the housing will let moisture in and to stay away from that type of install.
Thanks for any input.
Value Accessories
Hey, I have used Tricled and Value Accessories for lights and more, either one will provide you with good value, great products and outstanding customer support. Value Accessories has actually sold me some of my SpyderPops and Tricled parts, they offer good consulting with the product.
Joe
WELLLLLLLLLLLLLLLL
Although I don't have the LED's, I did drill four 1/4 inch holes ( 2 on top - 2 on bottom of both covers ) for air circulation. Which are open and allow considerably more water access to the bulb than anything Lamont is doing with the wire etc...... and I have had no issues with water ....... Mike
I installed Lamont's lights on several bikes with no problems. And a little caulking will fix any concerns.
Thanks for the reply.
I wouldn't think Lamonster would advise us to do harm to our bikes but I just needed to confirm with other members.
Back Brake Blinkers
Thanks
Do you have the "Back Brake Blinkers" for a F3-S model? I was looking at your site, but I couldn't find it.
LED Lights
Rivico has some universal mounts called S.O.M.A lights. (Stay Off My A**)
https://rivcoproducts.com/catalogsearch/result/?q=Soma
the small led's modulate when brake is lit the long strips are Tricled both are lit with just the tail lights.
2013 STL SE5 BLACK CURRANT
SpyderPop's: LED bumpskid
minispyder dash toy
Lid lox
KradelLock
Pakitrack
FLO (Frunk Lid Organizer)
BRP fog lights, trailer hitch
SENA 20S EVO
Someone already answered your question, sorry I just saw this.
We don't have brake flasher modulator for F3.
Only the run brake turn led for the center.
