BajaRon Shock Adjusters
Install is done on my 2015 RT LTD. I have a bit of problems getting those darn top bolts out but managed. Building the shocks is very easy but be sure to get Ron's compressors. They make it so easy. The reinstall went seamlessly except the instructions I had - never said when to install the bottom bolts but after a call to Ron, it is done. I didn't mess with the double sticky tape at all. I used a 3/8" breaker bar and a 15mm socket. I actually used two very tiny pieces of electrical tape to hold the nut in the socket. I slid the top bolt in so about 1/8 inch of the threaded portion extended thru the bracket. The nut on the breaker bar slipped into place perfectly and the bolt was very easy to thread int the nut. I then tightened the top bolt/nut and wiggled the socket/bar just enough to get the tape to come loose.
After three rides I have found my "sweet" spot! It is three turns out (Firmer) and the rear shock is set to the fourth firmest setting. The riding was done with a full tank of gas, one up and the bike was unloaded. The front bike height started at 6 3/4". After three turns and a full tank of gas, it settled in at 7 3/4" height after riding. It looks as though every turn on the adjuster adds about 1/2 inch to front ride height.
I do have the Ron sway bar and links and I found the bar helped sway a bit on my 15 - but not as much as it made on my 11. The shock adjusters DID make a substantial difference in the corners and especially on nose dive when braking. They diid not. affect the ride characteristics in a negative manner what so ever!
Riding two up will have to wait until nicer weather.
Thanks Ron!
2015 an Am Spyder RT Limited
2013 Yamaha WR250R - Sold
2011 Can Am Spyder RT-S SE5 Limited - Sold
2011 Aspen Sentry Trailer
2003 BMW K1200LT - Sold
2007 Unigo Trailer - Sold
2001 BMW K1200LT - Sold
2001 Honda 750 NightHawk - sold
2015 RT Ltd , Canamspyderaccessories Brake pedal ext. Red
Ozzie Ozzie Ozzie
Hey bmwlarry, with a significant height change like that, you might want to get the camber checked on your front wheels. Unless they were really sloping in to start with, there's now a good chance that you'll find the tops of the wheels are sloping out due to the lift; & that can make for very twitchy ryding, un-predictable cornering characteristics, & adversely accelerate the front tire wear.
this is ALL probably probable, love the idea of a little more ground clearance, but scrutinize those front tires for a couple thousand miles,
just to make sure nothing weird is going on. and thanks for the report.
Flatlander, Navy Veteran, Widower
Loved my 2014 RTS SE6 Pearl white
but have a new love now,
my 2017 RTS SE6 Champagne metallic (Champ)
Peter, My plan is to get a alignment done in the next two weeks. I haven't had one done for 1 year or 9,000 miles. It is due for a check
Thanks for this good info Larry,
Glad to hear it helped with your cornering, I am having the same issue.
I plan on getting the adjusters on mine for the Spring, and maybe giving it a shot myself.
Who do you recommend as I do not see them available from the Lamonster site ?
BajaRon
I thought Baja Ron only sold to dealers. Thanks, will contact them.
Did you put them back in reverse of the original direction? Ron suggests that and it makes it much easier to tighten them. I don't recall what wrench Ron recommends but I bought a 3/8" drive flex handle. A 3/8 drive socket is short enough with the flex handle to get into the tight space without too much trouble. As I recall when I installed mine I determined the flex handle would work better than what Ron suggests.
The shocks went in the same as OEM. I did reverse the bolts on top. The problem was simply the wiggling out of the loose upper bolts. Reinstall was a piece of cake!
SpyderLovers Sponsor
Not to hijack this thread. But I've always gotten a great deal of satisfaction from doing my own work. And I am quite frankly surprised at how many of you not only do your own installs, etc., but you're excited by the prospect of doing it yourself. It's great to share the experience of getting there as well as the results of a job well done.
What does the "sweet spot" feel like?
No, I'm not trying to get weird. I installed the adjusters a month or two ago, and I settled at 2 turns. I have been noticing what feels like buffeting at high speed, but I think it might be a reaction to the road surface because it tends to happen at the same areas of the road. It can be disconcerting to say the least to find that you are suddenly headed for the next lane!
When the adjusters are at the correct setting, what can I expect to feel? Conversely, when they are set improperly, what can I expect to feel?
I know I need a laser alignment to put the bow on top, and I want to get it dialed in as much as I can first. The height is pretty much the same as it was prior to installing the adjusters.
Myron Wooley
USMC 1975 - 1979
2nd Spyder: Pearl White 2016 Spyder RT Limited, purchased December 18, 2016 with 1 mile
First Spyder: Pearl White 2012 Spyder RT Limited, gone to a good home
