Results 1 to 17 of 17
Thread: FOBO TPMS ???
    Jul 2014
    Tampa FL Area
    Default FOBO TPMS ???
    I just installed the fobo tpms but noticed the sensor is less than 1/8 inches away from the rim.
    There is only enough room for two large size zip ties. If I press on the sensor it will touch the rim.
    Would this be an issue, would gravity make the sensor to hit the rim?
    Very Active Member samewok's Avatar
    Oct 2011
    Jacksonville,Ar
    I have had them for almost a year and no problem with them
    4" Stubby antenna, Dual arm LEDs Fender LEDs, Back Rest, Luggage Rack, Run, Brake and Strobe for top case, Mirror LEDs,Back Off decal on mud flap, reciptal for Battery Tender and Heated Gear, mirror LEDs that stay on or work with blinkers, GPS, side bag red LEDs, Top cuff with Ram Ball phone holder And USB power, Top cuff with drink holder and passenger cup holder. Also grilles in front of radiators, also spyclops. Garmin 595 GPS, Freedom windshield. Also glove box console And trunk wrap in carbon fiber from wrap my spyder. BRP comfort seat. added garage opener with rocker switch in center console to match other switches. And I have added Elka stage 2 shocks.
    15 rt , yes Black
    Very Active Member DJFaninTN's Avatar
    Sep 2013
    Panama City Beach, FL
    do you often ride around with zip ties on your tires?
    if not, then it will not be a problem.
    2015 RT Limited Intense Red Pearl
    Northern Kalifornia
    Default Not a problem
    I've had mine for over 6 months now with no issues at all. If I were you I wouldn't worry about it. Enjoy the ride and the FOBO's. Great product.
    Very Active Member garb55's Avatar
    Coolidge Arizona
    Quote Originally Posted by DJFaninTN View Post
    Maybe the zip ties make his OEM tires last longer
    Now 2014 RT Limited Cognac
    Was 2008 GS SM5
    Don Garbarino
    Cup Holder
    GPS locking holder
    Mud flap
    Modified KNOTT grill
    Phone holder and charger
    Trailer hitch
    Dual air horn
    Auxiliary fuse box with relays
    Heated clothing controller
    volt/oil pressure gauge
    Sequential signals in mirror
    Tri Axis Handle bars
    Baja Ron anti sway bar/heim links
    shorty antenna
    And many more
    Nov 2012
    South Texas
    Default FOBO
    I have had mine installed for about 3 months with no problems, except they seem to register 3 to 4 PSI higher than with a manual gauge.
    Any ideas why?
    Jul 2014
    Tampa FL Area
    Quote Originally Posted by ValleyRider View Post
    Any ideas why?
    I am having the same issue. Checked my pressure before and it was 18,18 front 28 back, put the sensor on and was reporting higher so I let air out on all 3 tires. Wonder which one is more accurate.
    Jul 2014
    Tampa FL Area
    Quote Originally Posted by garb55 View Post
    No matter what forum you go to there is always a comedian around.
    Very Active Member JimVonBaden's Avatar
    Oct 2016
    NoVA
    Quote Originally Posted by Papahoosh View Post
    If you only have one hand gauge, buy another. It is always preferable to have a back-up, and they are not that expensive.
    Jim
    2013 ST-S (wife's)
    2015 BMW R1200GS (mine)
    1981 Yamaha XS400 Scrambler Custom (mine)
    Oct 2016
    NoVA
    Also, I prefer metal valve stems. They never break, rarely leak, and are best to support these types of TPMS sensors.
    Jim
    2013 ST-S (wife's)
    Nov 2012
    Pueblo Colorado
    Default 2 sets of Fobo's - Pleased with their performance
    Got the first set for the wife and liked what they did, so got a set for my bike and have been pleased with them for over a year. They may read different from your gauge, (I thought they read a little less than my hand gauge, but they seem to agree well with each other when I switched them on tires to check. I would suspect that maybe the hand gauge is off. Never hurts to have a new gauge, although then you will always wonder which one is off.. I also worried about the stems flexing, but after 20,000 miles and no problems,,,ride more; worry less!
    2015 RT , OEM Black Gloss
    Active Member 5legsshort's Avatar
    Mar 2015
    Kansas City North, MO
    Default FOBO pressures
    Go into the app on your phone and find in "settings" that there is a option for Enable/Disable gauge pressure. I believe disable resorts back to atmospheric pressure & compensates for temperature or something like that which will be different than your gauge readings.
    I have a hand held gauge I checked against a calibrated dial gauge at work and it was within 1/4 psi of it. We have 3 on my F3 & 3 On the wife's RT and they all read correctly once I figured out I was on wrong setting in the app.
    Hope this helps instead of confuses you--
    Mar 2015
    Default FOBO explaination...
    Jun 2016
    Harrington, Australia
    Yeah......thank goodness for that, Paphoosh
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
    Jun 2016
    [PHP][/PHP]
    Quote Originally Posted by 5legsshort View Post
    I wouldn't have thought there would be too much variation in atmospheric pressure in Florida though, 5legs.
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
    Jun 2016
    I don't use FOBO as an absolute measure of pressure, but as a warning mechanism. I have found tyre pressures that suits me, and I use FOBO to ensure the tyres and shock remain around that pressure. This was very useful yesterday when I left the dealer after a service and the FOBO showed 29lbs in my rear tyre when I usually run 22lbs. They had checked the rear tyre and adjusted it to Kenda specs.
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
    Jul 2014
    Tampa FL Area
    Thank you it helped allot.
