Results 1 to 11 of 11
    Bossier LoUiSiAna
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Sep 2013
    lake mary fl.
    Thanks for the info! Even though bi already have a booster, that seem like a good deal! Would it be enough to jump start your car?
    Sep 2016
    LI NY
    Don't see a pig tail connector, but it could be too much for it to handle.
    2010 RTSM5 , stock Stock Silver
    Thanks for posting this!
    The price certainly seems to be reasonable...
    Mar 2015
    forrest above Reno, Nv
    Smile Jumper clamps
    The clamps are there to start a large battery but the wires sure look SMALL.
    Small wires cause:::::::::::: Kaos
    2014 RTS , Circuit Yellow
    Bossier LoUiSiAna
    Default A spider for your spyder
    Quote Originally Posted by Zip View Post
    Why would it need a pig tail connector? You cant jump start from those & that it its primary function. I agree The wire gauge may look small but is made to work. Small enough for the unit & pouch to fit in a glovebox.
    I should add i already have a booster also fyi it is a Stanleywalmart
    i like it but is a bit large & has a big button is lil too ez to push when packing away & it will discharge so i tape a fender washer over it. (Seen in pic). But what i really like about the unit is its built in safety so say if my sister needs it i can just drop off with her , something i cant do with jumper-cables.
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    SENA 20S EVO
    Sep 2016
    LI NY
    How well does it work? Do you go direct to the Battery or use the power takeoff?
    Sep 2016
    Alma,Arkansas
    Default A spyder for your Spyder
    I have the Stanley Power Pack, bought it from the Walmart clearance isle for $40.00. I have had to use the unit one time, works great. Unit seems to hold the charge well.
    Good
    Luck
    Jun 2014
    ny
    the price makes me think it is cheap chinese, i have 2 anti gravity micro starts @ 120 ea. & i wouldn't chance the
    time you really really need it to work.
    Bossier LoUiSiAna
    Has worked fine with direct to battery or the cig lighter plug in. he cig plug in just takes longer but allows you to get done without opening hood (on car anyway) I have only tested & used few times <5 & recharged when done, it proably didnt need charging but for my peace of mind I did anyway. It does the job as a back up for
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    SENA 20S EVO
    Sep 2016
    Alma,Arkansas
    Quote Originally Posted by SPECTACUALR SPIDERMAN View Post
    If price makes the unit "cheap Chinese" then sobeit. I could care less as long as it works.
    Cheap Chinese, where do you think the battery units for the Anti-Gravity are made?
    Good Luck
