The KILL SWITCH is nothing more then equivalent of an EMERGENCY SHUTOFF.
AJ
Printable View
AJ
That wonderful Kill Switch sold a lot of Batteries for us. BTW, a lead acid Battery sulfates much quicker with a low or dead Battery.
That kill switch has given me that semi-panicked, sinking feeling you get when the bike won’t start when it was running fine a little while ago… on EVERY 2-wheeler and 3-wheeler I have owned.
Years ago I belonged to a motorcycle club that had members who occasionally thought it very funny to push the kill switch on bikes in the parking lot.
I never saw the humor in it as they would all jump on their bikes and leave as fast as they could so you didn’t have anyone to turn to for help or rescue. This was before cell phones and on a Friday night supper run 75 miles from home, at 10:00 at night it just really was not funny at all when you are the last one left in the parking lot.
I never have, but always threatened to gorilla glue the switch in the “on” position.
There is no harm in using the KS. Besides regular use keeps the contacts clean. In the event of a need, or inadvertent use, knowing immediately where it is located doesn't hurt, either. If you don't want to use, then don't. But your ways are not the ways of everyone on this forum.
Only time mine goes from "Live" to "Kill(ed)" is when I bump it unintentionally.
Useful when a bike and its rider are on the ground and the engine is running.
My Spyder has an issue starting when hot, and my clumsy a$$ tends to hit the on/off switch when grabbing a drink from the cup holder.
Last night I ripped into the right handlebar controls determined to get to the switch and short it out. Two hours later, a dozen 2mm star screws including 2 hidden (They really don't want you in there) I got to the actual switch... to find out its on a ribbon cable, not wired. Another hour to reassemble and institute Plan B.
Plan B. Find a small sheet metal screw, carefully insert it on the bottom of the switch, locking it between the gap at the bottom of the switch hole and the switch.
I had some thin aluminum laying around so I built a quick switch cover so I don't accidentally hit it.
:agree: but I hafta say, dragging up a 2011 thread & post was a bit of thread archaeology! :shocked:
Still... I've discussed this before, so I won't add too much again - you can look up & read back thru the (now combined) thread if you really want to see my earlier posts. ;)
But for those who still feel the need to discuss this, just type "Kill Switch" into the Search field (up toward the top Right of the page); check the 'Search Titles Only' box in the Drop Down list; then submit the Search & do some reading.... You don't really need to do much more than read the thread titles to begin to work out why Kill Switches on modern EFI engines motorcycles are an anachronism that are probably more likely to cause you issues than they are save your life! :banghead: And besides, you don't have a big red button like that on your car, do you?! :rolleyes:
Enjoy. :thumbup:
Must be in the minority but: I always use the "engine stop switch" on every bike I ride. Guess it's one's choice of what seems easy. Simple & convenient. Never really tried to start a bike with it in the "OFF" position. Same procedure for the past 43 years: Key "ON", "Engine Stop switch "RUN" (listen for fuel pump to pressurize), Hit the "Starter Button". Spyder adds a step or two but no biggie. Do what works for you and have fun.
The reason manufacturer's recommend using the kill switch is this builds automatic muscle memory so that in case of emergency, you're not hunting around for the correct switch. It also alleviates the issue of someone activating the kill switch and the rider not understanding why their machine won't start. Happens more than you know.
On some machines, the ignition switch is in an awkward spot forcing the rider to take one hand off the handlebars and reach around for it. Not a big deal on the Spyder because it can't fall over. But on 2 wheels, more of a concern in slippery or unstable situations.
Neutral, engage park brake, turn ignition off, remove key. I'll test the kill switch every once in awhile.
What folks FAIL to understand is the word KILL!
It is there for EMERGENCY shutdown of the engine.
Do you KILL your CAR?
BUT do as you want but remember this. ALL toggle switches eventually fail.
With 57 years of riding, I only used a KILL switch once immediately after an accident when the engine REQUIRED an emergency shutdown.
Also remember this - those telling you to use the switch are more likely INEXPERIENCED riders themselves.
But like I said, what ever floats your boat.
AJ
My emergency stop switch was used once by some d(ckhead at a fuel stop on a group ryde with a bunch of 2 wheelers that I didn't know. I went in to pay and my :spyder2: didn't spring to life as usual. I gave the group a sinister look, flipped the switch to "run" as though nothing happened. They stopped snickering.....
Many moons ago I accidently hit that switch on my CB900F while loading up. Took more that a few minutes to figure it out. I've been much more careful over the past decades.
Lew L
