Originally Posted by
PMK
Sounds like a very good plan. I would add though, if you see any residue of the oxides from fretting, replace the pulley. If it were me, I would utilize a light colored or glass bowl, large enough to submerge the pulley. Partially fill with Iso alcohol. Then, without submerging the pulley initially, wash the splines and center bore with an old toothbrush. Pass the brush through the bore dipping into the alcohol, and then washing the splines over the alcohol to let any debris drop into the bowl. This will allow a good visual indication by seeing oxide remnants into to alcohol, at the bottom of the bowl.
If no oxides are noticed, wash the entire pulley and output shaft splines very clean. Reinspect for wear, hopefully none is noticed. Lubricate and install the fastener. Once you have accomplished the task, future inspections and reapplication of lubricant is fairly quick and easy. As a suggestion, reinspect at around 14,000 miles, then at the 28,000 mile scheduled maintenance. I suspect with moly paste, the interval will then be at each 28,000 mile scheduled maintenance therafter.
