Drive belt vibration above 65 mph on 2014 RT
My 2014 Spyder RT Limited only has 4000 miles. It runs flawlessly until I get on the Interstate above 65 mph and there is an intermittent vibration. I was shocked the first time it happened. I read on Spyderlovers forum and figured out that it has to do with the drivebelt vibration and talked with the service dept at the dealership my Spyder came from. Unfortunately the dealership is 600 miles away. I'm just wondering if the warranty covers this. I'm led to believe from the forum that the belt tension or alignment is off. Any suggestions ...and would this be corrected by warranty?
Step 1 : Read the directions Step 2: Follow them Step 3: Ride happily
You can choose to be a victim of " belt issues " or you can choose to purchase a Gates sonic tension meter and a manual. Read and follow the directions and you will amazed at the results. I chose to do this and now whenever I feel belt vibration, I pull in my garage and check the belt. Don't be a victim of dealer BS, take control. It's very empowering. You don't need anything aftermarket to fix this. The only thing I would change in the instructions would be to increase belt tension 1/8 of a turn at a time, instead of the recommended 1/4 of a turn at a time as this is way too much change between checks. Take a "Sharpie" and mark where the tensioner is before you start adjusting.
