Originally Posted by
hellridgeryder
I have a 15 RT L purchased new. Current miles 11000. It was laser aligned by the dealer when purchased new. After it was aligned I replaced the sway bar. Front tire are original. I noticed what I thought was excessive road noise from the front tires. After checking the front tires I found both were cupped on the inside. Tire pressure is 18 #. I'm interested in knowing what is most likely causing the cupping. I assume alignment issue? Remedy? New front tires and re-alignment?
