I finally tackled the dreaded air filter change on my 14 STS. Actually, the worst part was removing all of the necessary panels and stuff to get to it. Geez, what a tight fit it was though. The factory manual calls for removing most of the entire front components to do the job but I was able to get by with removing the right side panels only. There is a tubular frame member and some wire harnesses in the way, but I was able to pull the front cover far enough away in order to pull out the old one out and replace it with a K&N filter.
The old factory filter was actually very clean looking after almost 2 years and 21K miles.
Next time should be easier. :clap:
