Originally Posted by
PMK
Thanks for the vote of confidence. Your reply got me recalling a previous attempted helping a Spyder owner. Was in regards to bleeding brakes. A woman owned the Spyder. Her boyfriend or husband supposedly had every tool ever made and is a great mechanic.
This was bleeding brakes on the front of the Spyder. In simplest words, I explained to pump the brakes, hold pressure then open the bleeder screw, and capture the old fluid using a hose on the bleeder screw and place the other end in a jar. Close the bleeder prior to raising the brake pedal.
The genius master techs, insisted the bleeder was the brake hose attachment point on the caliper. So they attempted to bleed brakes by disconnecting the brake hose completely. They failed miserably.
Unfortunately, the horror stories posted here nowadays mimic that brake bleeding saga.
Suffice to say, I no longer discuss brake bleeding process with owners. This place is all about tire pressure, what tires and what oil...
