In the 5 pins plug by the right saddle bag, what color wire applies to each function, ie: turn signal, brake, backup, etc... ?
Printable View
Assuming you are referring to the 5 pin connector that the right hand tail light assembly is connected to they are as follows:
Pin Color Function
1 white Brake light
2 orange Running light
3 brown/black strip Backup light
4 brown/yellow strip Right turn light
5 black Ground
If this isn't the connector you are referring to post a picture of it's location.
Thank you but you list on #2 Orange Running Light. Shouldn't that be Red running light?
Can I assume there is another connector by the left saddle bag that also controls the Left Turn Signal?
Based on this, is each side (Left/Right) is controlled by its own 5 pins connectors? I'm new and learning. Thanks.
Thanks.
The column labeled color is the color of the wire not the color of the light. The column labeled function explains the function of each wire. You are correct that there is a 5 pin connector for the left side The wire color an function is the same for pins 1,2,3 and 5. Pin number 4 will be a gray/pink stripe wire and it is for the left turn signal.
