:popcorn: Page 6 :yes:
Printable View
:agree: but mine is do to knee surgery recovery. cueman
Thank you my friend, this is my third knee surgery and I’ve still only got two knees! :yikes: cueman
I see nothing in the Federal regs that states a manufacturer cannot use a car wheel on a motorcycle if the motorcycle maker deems it to be suitable. So if it does, then any tire that a tire maker says can be mounted on that specific rim can be used on the motorcycle. I have no easy way to verify it, but I'm sure even though HD wheels are designed specifically for HD trikes, i.e., the bolt hole pattern and offset are not the same as most car wheels, the tire mounting cross section profile is identical to a standard Tire & Rim Association profile for car tires. So when Dunlop, Goodyear, or whoever says a P205/R15 is designed and approved to fit on XX rim profile, and the HD wheel matches the XX rim profile, there is nothing to keep HD from mounting that car tire on their rim.
In short, since HD wheel has XX profile, and ZZ tire is approved by its maker to fit on XX profile rim, HD can mount ZZ tire on its XX profile wheel.
Now, why didn't BRP choose to use car tires on the Spyder when it was developed? Good question for which we'll never get an answer. But I'm going to speculate that when Bosch was developing the VSS software, or Nanny, the engineers determined that the tires needed to have some certain handling characteristics that most car tires did not provide so they said the Spyder needs a tire with special characteristics. BRP probably then decided to use a wheel size that was not being used for cars to ensure that only tires meeting the Bosch requirements would be used on the Spyders. Again, this is my speculation. We can be sure BRP will never tell us the real story. Keep in mind that what Bosch knew about how the Spyder would handle is quite a bit different than what they understand today. Otherwise we wouldn't see the relaxation in Nanny controls that now exist. If Bosch and BRP knew back in 2005 what they know now, quite possibly they would choose to go with standard car tires.
Thank you, thank you :thumbup: …. as far as your paragraph #3 goes … The Kenda tires have had four iterations since original design, imho there is no way all four could have been covered by the orig. Bosche VSS & traction control system ….. so the tires do not enter into the equation … not the physical composition, not the number of plies nor the tread pattern of the tires really matters.... Our cars and trks can pretty much use whatever you put on the Rim / Wheel …. and the same goes for the Spyder. …. I also agree there is quite a lot we will never be privy to from BRP. … The only difference between the HD wheels and Spyders is the hub / bolt pattern and back-space. They are both " J " type rims & MUST have tires with " J " type wheels..... BRP can ( & will ) spin this to suit themselves but the Truth matters...… thank you for the pleasant conversation ….. Mike
I'll add to the page count. 165/60R15 Vredestein fronts mounted/balanced. 18 PSI sound right ? :)
** Found a thread. Gonna start at 17# **
I've the 165/60R15 Vredestein fronts mounted/balanced. Couldn't be happier even though I've only put about 75 miles on them. Also went up to 18 psi.
Lew L
On the subject of tires and wheels......
I removed a front wheel for the first time and attempting to put it back on was a nightmare. Good thing my 10 yo great grandson was helping me and I had him spot the studs and holes alignment for me. This took a lot of muscle work and time, so I want to know, what's the trick to mounting the wheel?
Just like an old VW Bug with the large bolt pattern. You sit on the floor, make a Y with your feet (heels on the floor, toes pointed out), put the tire on your toes and adjust as needed until the holes line up. nojoke I did this many times with my Bug and it works with the spider too if it's up high enough. It's always handy to have another pair of hands and eyes to help out also.
Is it just me or do others think the recent posts are way off topic?
Hey, anything to make a new record page count and it's all good. :clap:
To remove a wheel with a new Kenda Kanine tire mounted on it, all you need is a BRP Tool # 593840DDX444920187WTF(*XX#!!!. You also will need a small ferret (preferably a grey/white one), a stick of dynamite, and a box of pitted dates (any brand). I'll leave the details for later.
:agree:. Added note- Don't raise the bike too high to use your feet to assist with the wheel lift, especially if using Kenda Canine tires. As an aside, if you ever put any lubricant on the wheel studs (or any bolt for that matter) you must reduce the torque by the proper amount based on the lubricant used. So coupling Vredestein tires with Amsoil lubricant on the threads you may have to use negative torque to get the appropriate clamping force! :joke:
:popcorn:
Thinking of giving these a try. Will give Kenda one more try.
Since I took a snow day on Thursday. I am going to tackle installing the new Kanine on my rear wheel. Will be removing the Arachnoid tire.
OK. Got my snow day Kanine Tire mounted today. :yes: Now have to remove wheel from bike yet and reinstall.
Took a few pictures.
Kanine Tire
Old Vee Rubber Tire
